Converting single speed Air filter to multi-speed
Forum topic by Scott C. posted 09-09-2014 03:55 PM 914 views 0 times favorited 5 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 2051 days
09-09-2014 03:55 PM
I’m looking at a used Delta 50-860 for my small shop (12’x22’). This unit is a single speed 850cfm, a bit over kill for my shop but leaves room for growth and the price is right. I don’t know much about the fans in these things, would it damage the motor to add speed control? Assuming I can find one that is appropriate for the electrical load. I’d like to be able to turn it down while I’m working in the shop, but still be able to crank it if I’m cleaning up the shop.
-- measure twice, cut once, swear and start over.
5 replies so far
View TechTeacher04's profile
TechTeacher04
383 posts in 1531 days
#1 posted 09-10-2014 12:05 AM
You did not specify how you would be hooking the dust collector to your tools, direct to tool or connected through interconnected pipes or hoses. I would be leary of adjusting the speed. By connecting the tools in series you will decrease the suction at each tool achieving the lower cfm at each tool. Install bast gates and you can increase the cfm for the clean-up you mentioned.
Scott C.
#2 posted 09-10-2014 12:08 AM
This is an ambient air filter, to supplement my existing dust collector.
View Jim Finn's profile
Jim Finn
2656 posts in 2922 days
#3 posted 09-10-2014 12:32 AM
Your air filtering unit is most likely powered with an induction motor, much like your furnace fan is. You will kill an induction motor with a speed controller. Speed controllers are only for Brushed (Universal) motors not for induction motors. You can install a multi-speed induction motor but will have to choose a speed and stick with it. This is common on furnace fans.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
Scott C.
#4 posted 09-10-2014 01:00 AM
Thanks Jim, that’s exactly what I was looking for.
View rick1955's profile
rick1955
264 posts in 1430 days
#5 posted 09-12-2014 01:50 PM
If you switch your motor to a PSC (permanent split capacitor) or shaded-pole single phase induction motors you can get variable speed.
http://www.invertekdrives.com/variable-speed-drives/optidrive-e2-single-phase/
Or switch to a three phace motor and use an inververter. www.factorymation.com
Or switch to a DC motor. www.surpluscenter.com
-- Working smarter with less tools is a true crafts person...
