What do you use to hold finish while finishing?
Forum topic by CharlesA posted 09-09-2014 02:24 PM 1127 views 2 times favorited 19 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3361 posts in 2038 days
09-09-2014 02:24 PM
Topic tags/keywords: question
IN order to keep my Arm-R-Seal pristine, I am working on always dispensing some from the can, closing the can back up, and not returning any to the can. I’ve just been using cheap disposable plastic sandwich type containers to hold the currently used finish until the end of the project.
Any better ideas?
19 replies so far
View Fred Hargis's profile (online now)
5242 posts in 2733 days
#1 posted 09-09-2014 02:30 PM
I save all manner of plastic containers just for this….the most common I have are the 16 oz. cottage cheese containers. But I also have a few smaller ones: Chobani yogurt cups are especially useful, and I’ve used paper Dixie cups (the smallest size) for the really small jobs. One thing about the cottage cheese cups, I can put the lid on them and stick them in the small fridge I have in the shop as I wait for the finish to dry between applications. these same containers also get used for the glues that i have to mix, like the plastic resin glue.
CharlesA
#2 posted 09-09-2014 02:34 PM
I’ve used yogurt containers as well, but If I don’t have much in them, they are tippy.
We don’t eat much cottage cheese—probably why I haven’t thought of that.
View Billy E's profile
Billy E
162 posts in 2320 days
#3 posted 09-09-2014 02:45 PM
I use Mason jars
-- Billy, Florence SC
View Thewoodenmind's profile
Thewoodenmind
6 posts in 1600 days
#4 posted 09-09-2014 02:46 PM
My favorite containers are those with lids for the same reason Fred H listed. I have used a lot of leftover plastic and glass containers to hold finish. In addition to not returning finishes keep original can pure I often mix stains and dies (not with each other) and therefore cannot return them to original containers making a more permanent container necessary. For these I use glass jars most often baby food or old sauce jars. I just apply a label and then it is there for touch ups or if I want to repeat a certain color in the future. When I am using a wipe on technique I poke a few small holes in the metal lid of the jar and tilt it onto the rag as it is not always easy or clean to dip the rag down in a small neck of a jar like a baby food jar.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2610 days
#5 posted 09-09-2014 02:51 PM
I use these :
They’re the 1/2 pint wide-mouth canning jars from Target ($4.29 for a pack of 4). I like them because they’re resealable, and the wide mouth is big enough to dip a brush or cloth into. I take a sharpie and label the tops (I use them for Arm-R-Seal, shellac, dyes, BLO, etc). When I’m done with them, they’re fairly easy to clean out because nothing sticks too well to them.
I also have some large ones with flip-top lids and rubber gromets that I used for mixing dyes and stains in larger batches. I picked those up for a few bucks at Christmas Tree Shop.
CharlesA
#6 posted 09-09-2014 02:52 PM
Ed, Thanks. Those look great. I had dismissed Mason jars b/c I was thinking of full size ones.
BinghamtonEd
#7 posted 09-09-2014 02:53 PM
If you give cutting boards as gifts, those half-pint ones also are a good size for giving oil with it. I mix up mineral oil and beeswax to give with mine, and everybody gets a half-pint of that with their board.
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#8 posted 09-09-2014 03:06 PM
- BinghamtonEd
Great idea BinghamtonEd! Forward thinking with a nice gift and a fine cutting
board as well.
Billy E
#9 posted 09-09-2014 04:15 PM
I use these :
- BinghamtonEd
I use those exact same ones
View LeTurbo's profile
LeTurbo
234 posts in 1825 days
#10 posted 09-09-2014 06:59 PM
Cheap ceramic breakfast bowls. I think they cost about 90c in your language. If the paint dries out, I can usually peel it out. To keep it wet, a little clingwrap.
View jmartel's profile
jmartel
8286 posts in 2390 days
#11 posted 09-09-2014 07:52 PM
The finish doesn’t stick to the inside of the mason jars? I would think that it would make a mess in there and you’d have to buy more every so often.
TheWoodenOyster
1317 posts in 2175 days
#12 posted 09-09-2014 08:55 PM
Good call Ed. I might need to score some of those.
-- The Wood Is Your Oyster
View gfadvm's profile
gfadvm
14940 posts in 2930 days
#13 posted 09-10-2014 12:40 AM
I use these :
They re the 1/2 pint wide-mouth canning jars from Target ($4.29 for a pack of 4). I like them because they re resealable, and the wide mouth is big enough to dip a brush or cloth into. I take a sharpie and label the tops (I use them for Arm-R-Seal, shellac, dyes, BLO, etc). When I m done with them, they re fairly easy to clean out because nothing sticks too well to them.
- BinghamtonEd
I use those as well and the lids won’t stick if you screw them on over a couple of layers of Ziplock bag plastic.
BinghamtonEd
#14 posted 09-10-2014 12:13 PM
I use those as well and the lids won t stick if you screw them on over a couple of layers of Ziplock bag plastic.
- gfadvm
Hm, didn’t think of that. I have a roll of cling wrap in the garage I put on cauls, I bet that would work as well. Thanks!
View bandit571's profile
bandit571
22020 posts in 2923 days
#15 posted 09-10-2014 12:24 PM
I stopped at the Paint dept. at Lowes. They had a few plastic cups…CHEAP. Currently have a “large” one sitting on the bench. It has a BLO-Varnish- Walnut stain mix in it. and a cheap brush. Hasn’t set up yet. Seems to do the job, for about $.98 + tax.
