How do I drill a 3/4" hole 6" deep?
Forum topic by pressjockey posted 09-09-2014 12:21 AM 1249 views 1 time favorited 10 replies Add to Favorites Watch
View pressjockey's profile
55 posts in 1499 days
09-09-2014 12:21 AM
Topic tags/keywords: lathe drill question
I would like to drill a 3/4” hole 6” deep into a 3”x3”x7” piece of wood for a flower vase. I did a prototype and segmented the wood into 2-2” sections and 1-3” section and drilled through the 2” sections then 2” deep into the 3” section then glued them back together. I’ve been comissioned to produce 24 vases for a wedding and 8 more for christmas gifts. Segmenting takes time and it’s dificult to glue them back together perfectly so a 3/4” test tube fits into the hole. I have a bench top drill and cannot drill a 6”deep hole. I do have access to a lathe. I’m thinking that is the solution but the lathe owner is not very knowledgeable about the lathe’s capabilities and does not have very many accessories. Any advise would be greatly appreciated. Thanks, and sorry for the long winded post.
-- Pete, Whitehall, PA
10 replies so far
View Wally331's profile
350 posts in 1957 days
#1 posted 09-09-2014 12:23 AM
A brace and bit would make quick work of it, you could even drill as deep as you want on the drill press to get a hole to guide it, and then finish the hole with an auger bit. A 10” sweep brace would be fine, but 12” even better with so much friction.
View cutmantom's profile
401 posts in 2966 days
#2 posted 09-09-2014 12:37 AM
use a paddle bit, starting with a drill press as already mentioned will give you a good straight start
1313 posts in 1867 days
#3 posted 09-09-2014 02:12 AM
ditto ^
-- The Wood Is Your Oyster
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3644 days
#4 posted 09-09-2014 02:22 AM
If you were closer I’d say “Come on over and use my drill press and a 3/4 Forster bit”, but instead I’ll ask how long is the travel on you bench top drill press? Could you swing it around and rig a lower platform for it?
10086 posts in 3579 days
#5 posted 09-09-2014 02:30 AM
With the above methods I would run some tests to
make sure the bit tracks straight enough.
Another way to do it is by splitting the vases in
half and using a core box router bit to excavate
a channel. A jig can be devised for drilling dowel
holes so the parts can be glued together with
accurate alignement. I suppose a metal rod or
pipe would not stick to the glue and could
be used to align the halves. Wrap sandpaper
around a dowel to sand glue squeeze out off
the inside if it is present enough to interfere
with the test tube fitting it.
Drilling straight holes in end grain can be problematic.
People ask similar questions often on the forum
though often the hole desired is much longer
for lamp wires.
View Grandpa's profile
3259 posts in 2607 days
#6 posted 09-09-2014 02:55 AM
I have used the above mentioned core box router bit and glued it together. I made an oak pole lamp years ago using this. If you want to use something to align the pieces. use double sided tape and attach waxed paper to the dowel. the paper will turn loose and it will be straight.
View waho6o9's profile
8130 posts in 2508 days
#7 posted 09-09-2014 02:59 AM
Congrats on doing 32 vases. If it were me, I’d get a colt bit and chuck it up
in a lathe, it’s the most efficient way.
I have a colt bit designed for end grain like the one pictured above and like it a lot.
HTH and good luck now.
View RPhillips's profile
1157 posts in 1768 days
#8 posted 09-09-2014 03:01 AM
Use a paddle bit and then use blocks under the piece to keep raising it up as you drill deeper. You could also start off using the drill press and finish with a hand drill.
-- Rob - Indianapolis IN - Learning... one mistake at a time...
View bigblockyeti's profile
5051 posts in 1652 days
#9 posted 09-09-2014 03:13 AM
I have used a self feeding auger bit for something similar to what you have described. Doing it in a drill press with a self feed bit requires a good vise, slow speed and a quick hand to turn off the power once the desired depth is achieved. Doing it with a hand drill requires a drill with a lot of torque and a well secured work piece. Neither of these options is very viable in anything more dense than douglas fir.
View Nomad62's profile
726 posts in 2890 days
#10 posted 09-10-2014 08:55 PM
Put the pieces on the test tube, then glue them back together?
