earlex 5000 HVLP seal leaking
Forum topic by JesseTutt posted 09-08-2014 08:28 PM 1012 views 0 times favorited 2 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2074 days
09-08-2014 08:28 PM
Topic tags/keywords: spray finishing earlex 5000 hvlp seal
I have had the Earlex 5000 HVLP spray system for about four years and it has been doing a good job. ALthough I only spary about four or five times a year.
Today I sprayed water based Poly and as I was cleaning up I noticed a little bit of poly in the back half of the needle where the spring is located. I suspect that the seal that the needle is passing through is beginning to leak.
What can I do to prevent the leak?
Is the any preventative maintanence that I should have been doing?
2 replies so far
View pjones46's profile
pjones46
1001 posts in 2607 days
#1 posted 01-21-2015 01:38 AM
I would go to the source:
Contact us
Toll-free: 1-888-783-2612
Email: questions@earlex.com
8:30 a.m.-5:30 p.m. EST
-- Respectfully, Paul
17936 posts in 1821 days
#2 posted 01-21-2015 01:50 AM
If I remember correctly you’re supposed to occasionally put a bit of mineral oil on the needle and then when it slides in it lubes that seal a bit. I try to do this occasionally. I believe you can replace that seal with a bit of disassembly. Perhaps Sam will come along and have a better answer.
