Hardwoods and price differnce between 4/4 and 8/4
« back to Coffee Lounge forum
Forum topic by Manderson posted 02-04-2009 04:13 PM 1118 views 0 times favorited 8 replies Add to Favorites Watch
View Manderson's profile
Manderson
13 posts in 3934 days
02-04-2009 04:13 PM
I have several projects in que and I’m off to buy lumber at the local lumber place.
Intending to do my own resawing and resurfacing I wanted the greatest volume for the lowest price.
Can some one explain to me why I will pay more for 8/4 rough sawn than 4/4 sawn?
I’d expect that 8/4 would be cheaper a board foot since it would be in rougher form.
Help…..brain hurting…must …get ….wood.
Mark
8 replies so far
View Julian's profile
Julian
880 posts in 3433 days
#1 posted 02-04-2009 04:23 PM
For one, the thicker lumber is harder/slower to kiln dry.
-- Julian, Park Forest, IL
16272 posts in 4126 days
#2 posted 02-04-2009 04:25 PM
It’s not odd if you think about it. Why is a 1 carat diamond more expensive than ten 1/10 carat stones? Because the bigger the stone, the rarer it is.
You can mill a lot of 1×2 pieces from even a crummy log. But a log you can cut a nice 2×12 from is a lot rarer, relatively speaking.
Manderson
#3 posted 02-04-2009 04:30 PM
so throwing out needed thickness. So The cheapest form would be to buy 4/4 and resaw for thinner and laminate for thicker?
#4 posted 02-04-2009 04:45 PM
Mark, unless you are milling your own lumber as Rob suggests, buying 4/4 is probably the cheapest way to go. You just have to decide if having a visible joint when you laminate will be acceptable to you for whatever project you’re working on.
27251 posts in 3730 days
#5 posted 02-04-2009 04:49 PM
You could save money by laminating the thinner stock but how much is your time worth? This is of course discounting the glue, clamps, “mistakes”, etc.
I had to do this recently because I did not have any 8/4 stock available. Basically I had to mill it twice. Once to get it squared up and get one face of the lumber ready for glue-up and them again to prep the rough face and re-square of the other sides. The pieces came out fine but there is a glue line that I can see which will be hidden in the final build. But if I had not gotten a good glue-up then the piece would have been recycled and the process started again.
#6 posted 02-04-2009 04:59 PM
Maybe I’m lucky, but I’ve done laminating a number of times with 4/4 S2S lumber, and I’ve never had a problem, even without running it through a jointer. The glue line has been visible, but only because of grain variations. I’ve found it a pretty easy process.
But, as Scott said, I did it because I had no 8/4 stock readily available. If I could have driven down to the local yard and picked some up for just a slightly higher BF price, I’d have done it and saved the trouble.
View sIKE's profile
sIKE
1271 posts in 3662 days
#7 posted 02-04-2009 06:24 PM
Manderson,
If your intent is to resaw down to 1/2” or 1/4” 4/4 stock will be your cheapest route.
As with anything in life Bigger is better….and therefore more expensive.
35100 posts in 4308 days
#8 posted 02-09-2009 05:35 AM
The problem with resawing to 1/2” is you need to cut it to about 5/8 or a little less so you can clean it up to 1/2”. So it you were trying to get 2 1/2” pieces its usually not possible.
Start with 5/4 and maybe it’s OK. but start with 8/4 and you get three pieces easily. It some cases it might be cheaper to buy the 8/4 instead of 3 4/4 boards to get the 3 1/2” finished pieces.
Just my 2 cents. I did resaw a 5/4 board into 4 – 1/4” slices and sanded it to 5.2MM to put in a stile and rail door with a metric slot. The router bits were made for metric plywood. I was able to salvage a lot of wood that way. I made all of the kitchen cabinet door panels with maybe 16BD ft of some superb looking wood. I was able to make 4 bookmatched doors from one board 1 X 12 30” long.
