Creating blanks from laminating uncut boards?
« back to Woodturning forum
Forum topic by csnyderdvm posted 09-06-2014 04:08 AM 1316 views 0 times favorited 6 replies Add to Favorites Watch
View csnyderdvm's profile
csnyderdvm
20 posts in 1733 days
09-06-2014 04:08 AM
Topic tags/keywords: turning bowl blanks
I’ve seem the YouTube vids and threads about calculating the cuts in boards to glue and stack to create bowls to turn and finish. Since I am brand new it turning, would it be a reasonable alternative to laminate a total of 2-3” of 3/4 inch stock (6” wide maple) into bowl blanks for the purpose of practice? I recognize there would be a lot of waste wood as opposed to cutting out the rings, but the purpose is more for practice?
Thoughts?
Thanks in advance!
Chris
View Nubsnstubs's profile
Nubsnstubs
1286 posts in 1724 days
#1 posted 09-06-2014 04:31 AM
For practice, why not go to a firewood supplier, and buy some wood to try, unless the practice you need is “Gluing wood” instead of turning wood.. ........... . Jerry (in Tucson)
View Tugboater78's profile
Tugboater78
2743 posts in 2186 days
#2 posted 09-06-2014 04:43 AM
Not a turner but if I ever get a lathe ill be raiding my neighbors wood pile that I help restock every summer.. for practice pieces
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View Woodknack's profile
Woodknack
11601 posts in 2374 days
#3 posted 09-06-2014 05:52 AM
Sounds like you are talking about the single board bowl? I haven’t made one but there doesn’t seem to be much calculation involved and it would be much quicker than gluing up then hollowing out solid wood.
View DIYaholic's profile
DIYaholic
19618 posts in 2669 days
#4 posted 09-06-2014 12:26 PM
Being new to turning myself and having never turned a segmented piece,
You should take this with a grain of salt…. for my advice may well be worth what you paid for it!!!!
I don’t see why this would not work. Just be sure to have tight glue joints, and clamp well.
Will this waist a lot of wood? YES.
Not necessarily a bad thing….
While watching Captain Eddie videos….
He regularly says: “EVERY cut is a practice cut!”
With that in mind….
While turning your practice bowls, try all kinds of different tools, cuts & techniques.
You can even practice different finishing products and techniques, then turn off the finish, rinse & repeat….
View gwilki's profile
gwilki
200 posts in 1467 days
#5 posted 09-06-2014 05:17 PM
I started out doing just what you are thinking of. I had a good source of offcuts of kiln dried lumber. I glued them on to blocks, cut them round on bandsaw and turned them into bowls. I made a lot of shavings, but since the offcuts were going to the burn pile, I didn’t feel guilty at all.
-- Grant Wilkinson, Ottawa ON
View Ron Ford's profile
Ron Ford
208 posts in 1726 days
#6 posted 09-06-2014 08:34 PM
I may be missing the intent of your question, but Denny Edwards YouTube on tuning a ‘dizzy bowl’ shows a variation on the ‘bowl from a board’ idea that you could adapt to make a bowl using scraps of wood laminated together. You can skip the more complicated portions and just use his tips to cut various size rings that will stack to make a bowl. No need for the parts about offsetting one to the next, etc.
See the video at https://www.youtube.com/watch?v=XJ1lV-UhkB4. Denny is a great guy and will send you the spreadsheet to be used to determine how to cut out the rings.
Hope this helps!
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
