Kreg automax
Forum topic by Medickep posted 09-05-2014 09:13 PM 1539 views 0 times favorited 13 replies Add to Favorites Watch
View Medickep's profile
Medickep
569 posts in 1766 days
09-05-2014 09:13 PM
Topic tags/keywords: resource
Hello-
I was wondering if anyone has any experience using the Kreg automaxx clamps:
https://www.kregtool.com/store/c29/bench-klampstrade/p75/automaxxtrade-bench-klamptrade--3-reach/
I was considering putting a few T-tracks in another bench I have, and than using these clamps to make a clamping table. I wanted to use standard T-tracks as Kreg wants a lot for their track and they’re also much wider than 3/4”. I’m just not sure these clamps would stay in standard T-track. I like how these clamps adjust to various thickness automatic and I thought a clamping table would be a nice addition to the shop!
Thanks in advance!!
-- Keith
13 replies so far
View Fish22's profile
Fish22
83 posts in 3142 days
#1 posted 09-05-2014 09:17 PM
I have used them and I think they are very good.
-- Bryan, South River, NJ
View buildingmonkey's profile
buildingmonkey
242 posts in 1576 days
#2 posted 09-05-2014 11:02 PM
I have a couple of the automax t track clamps, but do not use them with regular T track. Found some tracks on ebay that are 3/4” thick by 1 1/2” wide. I drilled and tapped the track, and used 1/4” bolts from under the table to bolt them from underneath, then applied another layer of ply so they are level with the top. Only have the track on the right side and the lower edge of the the table, bought a couple of the clamps with the plates, and plan to recess the plates into the table out in the center for making face frames.
-- Jim from Kansas
View copcarcollector's profile
copcarcollector
256 posts in 2146 days
#3 posted 09-05-2014 11:13 PM
I have used an aftermarket part to affix these clamps to my Festool MFT/3 table. Worked great and the automatic thickness adjusting is pretty cool too.
Medickep
#4 posted 09-05-2014 11:42 PM
Thanks guys, it sounds like they’re worth the price. I do have room to raise the bench a bit, so I suppose I could raise it some to make the tracks level. They’re just 44 a pop and I suppose I could get away with only two sections.
Copcarcollector-
What accessory did you purchase to make normal t track work? I could add way more track and keep the cost down!!
Does it work the same as the kreg ones?
-- Keith
copcarcollector
#5 posted 09-06-2014 12:19 AM
Keith – not for T Track, I use these in the 20mm dog holes on the Festool MFT/3 work table. The adapters I think I got on ebay, Seneca Woodworking and I think Veritas make a similar adapter as well
Medickep
#6 posted 09-06-2014 12:24 AM
Okay, thanks for the clarification.
-- Keith
View timbertailor's profile
timbertailor
1594 posts in 1453 days
#7 posted 09-30-2014 08:48 PM
Here is the assembly table put together with the AutoMaxx clamps and my review.
Hope you find it useful.
Medickep
#8 posted 09-30-2014 09:25 PM
Timbertailor-
I just happened to post mine today! That’s so funny!
-- Keith
View cynic73's profile
cynic73
32 posts in 1439 days
#9 posted 09-30-2014 09:48 PM
I
I did this to my assembly out feed table. I love it and it works great. I am thinking of adding a track down center of table.
timbertailor
#10 posted 09-30-2014 09:53 PM
Timbertailor-
I just happened to post mine today! That s so funny!
- Medickep
That was quick! and I just found it under projects.
You are going to love the clamps and the flexibility of an assembly table.
Medickep
#11 posted 09-30-2014 10:12 PM
I did some practice clamping and they really do hold stuff well!! I can see loving these and I’m stocked I didn’t have to but the expensive track!
-- Keith
timbertailor
#12 posted 09-30-2014 11:30 PM
I did some practice clamping and they really do hold stuff well!! I can see loving these and I m stocked I didn t have to but the expensive track!
- Medickep
Just keep the clamping pressure turned way down or you will pull your track out. That is why Kregg uses the wider dual purpose track. I had to go back and add a bunch more bolts to my track to prevent it from occurring.
Medickep
#13 posted 10-01-2014 12:31 AM
I’m not sure why, but I put a scre in every spot, probably cause I had a box of them! I guess I should be fine now!
-- Keith
