Very basic loose tenon.question
« back to Joinery forum
Forum topic by C_PLUS_Woodworker posted 09-05-2014 07:02 PM 1177 views 0 times favorited 4 replies Add to Favorites Watch
View C_PLUS_Woodworker's profile
601 posts in 2843 days
09-05-2014 07:02 PM
I am so new and dumb many things.
Got my MortisePal. Think I am going to like it.
Practiced a lot. A LOT
Using 1/4” x 1 1/4” loose tenons
Now ready to put the upper and lower rails and stiles on an entry way cherry table.
I have my plunges set to mortise 1/2” holes in the legs. The legs are only 1 3/4 square. From what I have read that depth is about right for the leg mortides.
I could drill much deeper mortides into the rails and stiles.
Should I ?
Is that good technique?
Intuitively it makes sense but with all the bonding strength of the glues it makes me wonder if I should just drill all the mortides at 1/2”
Any other comments re loose tendon joinery would be hugely appreciated.
Thanks in advance
4909 posts in 2429 days
#1 posted 09-05-2014 08:18 PM
Usually if I need longer tenons (deeper mortises) than 1/2”, I’d go up in tenon thickness to 3/8” or so, that lets you cut the deeper mortises with a larger bit. Cutting mortises deeper with a 1/4” bit can be done, and sometimes breaks bits. Personally, I’d stay at the 1/2” depth for what your doing…my guess is a m entry way table won’t be carrying a heavy load annd those tenons should be plenty strong.
View pintodeluxe's profile
5596 posts in 2749 days
#2 posted 09-05-2014 10:25 PM
I make tenons just about as long as the legs will allow. Where rails intersect in legs, I miter the tenons. I am comfortable with 3/4” long tenons, but 1-1/4” tenons are even stronger. Making a little sketch of the top of the leg will help you decide on dimensions.
Here is a 1.75” square leg with intersecting 3/4” long tenons. The tenons are 1/4” thick. The offset of the rails on the legs makes a difference too. In this case they are centered.
View AandCstyle's profile
3006 posts in 2193 days
#3 posted 09-05-2014 10:56 PM
Bruce, I like to make the mortise a bit deeper than the length of the tenon to make space for any excess glue. I also bevel the ends of the tenons a bit to make them easier to insert. Finally, don’t over tighten the bolt that is used to clamp your MortisePal to your stock. HTH
-- Art
#4 posted 09-06-2014 06:02 PM
you guys are so skilled and smart and experienced.
I mean it….............. thanks for the time you took to give me the detailed guidance you did.
