General tool 690-1 bandsaw available
Forum topic by pjn posted 09-04-2014 02:39 PM 2474 views 0 times favorited 1 reply Add to Favorites Watch
View pjn's profile
pjn
2 posts in 1388 days
09-04-2014 02:39 PM
I’m based in Bucks Co. PA and I’m looking to part with a hardly used General Tool 690-1 bandsaw (I bought it in 2005 and used it to cut the braces for a timber frame barn. I then moved and it’s been sitting in the garage and not used ever since. The saw is in excellent condition. Price: $2,000. Local pick-up only (saw weighs over 300 lbs.).
General 690-1 15in Wood Cutting Bandsaw
Features:
High quality, precision-machined, one-piece cast-iron frame.
16 gauge stamped steel doors.
Heavily-ribbed, high quality, solid cast-iron table polished to perfection with a 3/8” x 3/4” (9.5×19 mm) miter gauge T-slot.
Built-in 2 1/2” dust collection outlet.
Hardened steel upper blade guide, mounted on a steel arm with sealed ball-bearings for extra support.
Quick, easy, upper and lower wheel parallel alignment using a block and groove mechanism adjusted by a handle at the back of the machine.
Powerful North American designed, totally enclosed, fan cooled motor with a dynamically balanced cast-iron pulley.
One-piece, high quality, welded steel cabinet for maximum strength and stability.
Overall Dimensions:
Wheel diameter 15” (381 mm)
Wheel speed 750 RPM
Blade speed 3000 FPM (914 MPM)
Maximum width of cut 14 3/4” (375 mm)
Maximum depth of cut 12 3/4” (324 mm)
Min. / max. Blade width 1/8” TO 3/4” (3 TO 19 mm)
Blade length 111” (2819 mm)
Table size 15” x 15” (381×381 mm)
Table tilt 0° TO 45° (RIGHT) / 0° TO 10° (LEFT)
Table height 42” (1067 mm)
Specifications:
Motor M2 1 1/2HP, 230 V, 1 Ph, 8 A
1 reply so far
View Simmsy's profile
Simmsy
1 post in 1345 days
#1 posted 10-27-2014 09:01 PM
Is your 690 still available?
