Hope I'm in the right section here.
Forum topic by newwoodbutcher posted 09-04-2014 05:47 AM 820 views 0 times favorited 2 replies Add to Favorites Watch
View newwoodbutcher's profile
newwoodbutcher
730 posts in 2758 days
09-04-2014 05:47 AM
It’s not really a DC question I’m asking here.
I’m adapting a working DC system to add a second bandsaw and a Performax 16×32 sander. The plumbing is 4” black drain pipe. I’ve got all the connections sorted out including increasing the Performax DC from about 2 1/2” to a four inch port. The new saw is the Rikon 18” 10-345 set up for dedicated resawing and the other saw is an old 16” grizzly with a cast iron frame set up for general use. The Rikon has two 4” dust ports, one right under the lower guides and one at the bottom of the wheel well, perfect. My problem is the Grizzly. There is a 2 ½” port in the lower wheel well and that’s it. I’m thinking of enlarging the lower port to 4” and adding a 4” port right under the lower guides. I’ve never cut into a piece of cast iron in my life. I don’t know what to expect or what cutter or technique to use. But I’m sure I can figure that out. My real question is: If I cut a 4” hole in the side of my cast iron frame, will I ruin my band saw? Make it too weak? Any problems? It’s a perfectly flat surface the distance from the edge of the circumference to the edge of the frame is about 2” on one side. Any advice?
-- Ken
2 replies so far
View bold1's profile
bold1
291 posts in 1755 days
#1 posted 09-04-2014 09:00 AM
I’d leave those ports alone. At 2 1/2” the air is moving faster for the same amount of vacuum. By increasing the port size you’ll lower the air speed.
newwoodbutcher
#2 posted 09-06-2014 05:50 PM
Makes some sense. Any other opinions?
-- Ken
