Need a slippery surface
Forum topic by poospleasures posted 09-04-2014 12:19 AM 1057 views 0 times favorited 11 replies Add to Favorites Watch
View poospleasures's profile
poospleasures
706 posts in 2448 days
09-04-2014 12:19 AM
Topic tags/keywords: question
HELP-I’ve had a problem off and on for a long while. I make some projects which have moving parts which are nestled into rebates and others that are held together with rare earth magnets. The tolerances are pretty close. I’ve used several different finishes such as clear spray enamel, shellac, poly and lacquer. I notice the problem most in hot humid weather which we have a lot of in central KY. The parts will stick together and have to be kinda whacked to make operate. These projects are dry as some have been finished for some months. By inspection I can usually see the little spot where they stuck. Usually use fine paper and remove roughness and rewax the whole surface which will then operate as it should for some time then later will become stuck in usually a new place. I think I have heard of some type lub to be used on these type of sticking areas. I will be watching for your answers so thanks in advance.
-- I,ve had amnesia for as long as I can remember. Vernon
11 replies so far
View crank49's profile
crank49
4030 posts in 2934 days
#1 posted 09-04-2014 12:38 AM
Some folks lub things with Johnson’s Paste Wax.
You could use a dry film lubricant containing molybdenum if discoloration is not a concern.
View SuperCubber's profile
SuperCubber
1022 posts in 2248 days
#2 posted 09-04-2014 01:22 AM
What about dry Teflon spray or dry graphite lube?
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View doubleDD's profile
doubleDD
7316 posts in 2007 days
#3 posted 09-04-2014 03:01 AM
I use a cutting wax and it has given me good results.
View sawdustjunkie's profile
sawdustjunkie
382 posts in 1681 days
#4 posted 09-04-2014 03:18 AM
I remember using bar soap to lube wood drawer slides and that works well!
Don’t know if it would help your project, but it wouldn’t hurt to try it.
-- Steve: Franklin, WI
View InstantSiv's profile
InstantSiv
262 posts in 1559 days
#5 posted 09-04-2014 03:21 AM
Paste Wax. I made an mdf table saw wing and sealed it with poly. Plywood would drag a lot so I used paste wax and it’s super slick now.
View bobasaurus's profile
bobasaurus
3405 posts in 3148 days
#6 posted 09-04-2014 03:37 AM
I had the same problem with a wooden plane I made that had an adjustable mouth. The stupid mouth would stick no matter the lubricant I tried. Paste wax and teflon lubricant did nothing. The only thing that ended up working was dry graphite powder. It works like a charm even under pressure.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
117061 posts in 3541 days
#7 posted 09-04-2014 04:35 AM
Wax is simple easy and effective.
View OldWrangler's profile
OldWrangler
731 posts in 1558 days
#8 posted 09-04-2014 04:47 AM
I get pretty good results with a HD product called Dri Slide. Don’t know what is in it but it keep band saw box drawers from sticking. Spray or wipe on. A little goes a long ways.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
View johnstoneb's profile
johnstoneb
2863 posts in 2136 days
#9 posted 09-04-2014 12:40 PM
Your problem is wood movement from moisture. I build wooden geared clocks and have the same problem. As humidity increases the clock slows down and if it gets high enough (humidity) the clock will stop. What you are doing and some of the suggestions may reduce the effects of moisture. The only real way to dure it is to increase the tolerances and even then when the humidity gets really high like it can in Kentucky you may just have to live with it.
-- Bruce, Boise, ID
View Roger's profile
Roger
20923 posts in 2768 days
#10 posted 09-05-2014 11:48 AM
Parrifin wax does pretty good. You can buy it at the grocery store for a few bux. It’s usually near the canning supplies.
poospleasures
#11 posted 09-06-2014 01:35 PM
Thanks to ever one who commented for your advice. I have been waxing w/Johnsons or rubbing with paraffin, for years, but the sticking has shown up sometime in the last couple years. I was thinking maybe it was the new formulas being used in finish to meet government standards. I will try some of the ideas you all suggested. I guess I really want an easy solution.
