Best place to get good wood screws?
Forum topic by pizn posted 09-02-2014 05:16 PM 2238 views 1 time favorited 27 replies Add to Favorites Watch
View pizn's profile
pizn
13 posts in 1330 days
09-02-2014 05:16 PM
Topic tags/keywords: question joining
Hello,
I’m getting tired of the cheap screws at HD and would like to know where the community gets their screws? Even the “wood” screws I get at HD snap regularly when going into hardwood even when pre-drilled and countersunk. I can get good screws with square or Torx drive in lengths longer than 2”, but these are made for decking. I see a lot of YouTube-ers using nice, square-drive screws and I’m just wondering when those can be had? If they can’t be had at a national chain then I’d like to know of any websites where they can be ordered.
Thanks.
27 replies so far
View shopdog's profile
shopdog
577 posts in 3449 days
#1 posted 09-02-2014 05:23 PM
Try mcfeelys.com or manasquanfasteners.com
-- Steve-- http://www.urbanexteriors.biz
View paxorion's profile
paxorion
1107 posts in 2009 days
#2 posted 09-02-2014 05:23 PM
I get the Spax brand screws from HD that have either a Torx or a Philips/Square head. There is a night and day difference using these than the generic stuff.
-- paxorion
View Oldtool's profile
Oldtool
2596 posts in 2154 days
#3 posted 09-02-2014 05:25 PM
Try:
http://www.leevalley.com/en/hardware/Search.aspx?action=n
http://www.profhdwr.com
https://www.mcfeelys.com/index.aspx?aspxerrorpath=/index.aspx
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View CharlesA's profile
CharlesA
3312 posts in 1761 days
#4 posted 09-02-2014 05:28 PM
+1 on Spax screws from HD. They’re the best I've tried, period.
View pizn's profile
pizn
#5 posted 09-02-2014 05:39 PM
Are you able to get the Spax screws in a non-phillips drive under let’s say 2 inches? I’ve used them for longer sizes and they are great but I’ve never seen them in sub-2in varieties.
Thanks Shopdog for the manasquan fasterners link, that place is right by my house so I will check them out in person.
I’ll also check out mcfeelys as a couple of you have mentioned.
Thanks!
View cutmantom's profile
cutmantom
402 posts in 2999 days
#6 posted 09-02-2014 05:39 PM
sometimes you can find drywall screws that are no. 8 instead of no. 6, they are alot stronger
CharlesA
#7 posted 09-02-2014 05:51 PM
Drywall screws are brittle. I use Spax in 1 1/4, 1 1/2, and 2”. With HD, I order them online if they don’t have them in stock (or even if they do) and pick them up next time I’m in store.
paxorion
#8 posted 09-02-2014 05:55 PM
Are you able to get the Spax screws in a non-phillips drive under let s say 2 inches? I ve used them for longer sizes and they are great but I ve never seen them in sub-2in varieties.
I ll also check out mcfeelys as a couple of you have mentioned.
Thanks!
- pizn
Like Charles, I have a spread of Spax screws from HD under 2. Here's an example of my the 1 1/4 />http://www.homedepot.com/p/SPAX-8-1-1-4-in-Phillips-Square-Flat-Head-Wood-Screws-240-Pack-4101010400326/202040997
-- paxorion
View pizn's profile
pizn
#9 posted 09-02-2014 05:58 PM
Like Charles, I have a spread of Spax screws from HD under 2. Here s an example of my the 1 1/4 />http://www.homedepot.com/p/SPAX-8-1-1-4-in-Phillips-Square-Flat-Head-Wood-Screws-240-Pack-4101010400326/202040997
- paxorion
Do you guys ever have problems with the phillips drive on these? I’d really prefer square or star/torx.
CharlesA
#10 posted 09-02-2014 06:01 PM
I only use the torx.
CharlesA
#11 posted 09-02-2014 06:25 PM
These:
View ChrisK's profile
ChrisK
1942 posts in 3045 days
#12 posted 09-02-2014 06:29 PM
In reference the Phillips drive. About 3 years ago I started using a 1/4 impact driver to drive screws. I still properly pre-drill holes in hardwoods, not so much for 2x work. The impact driver really does a great job. I have used it on on small #4 screws and 5/16 lag bolts. When the screw starts to tighten the impact mode clicks in and the rpm drops to almost zero. You can tighten the screw one hit at a time with practice. It is also great for taking out a lot of screws.
-- Chris K
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2333 days
#13 posted 09-02-2014 06:30 PM
I’ve used the Rockler square drive dry-lubed screws for a couple projects now, and I really like them. I got the pack that has 400 (100 each of 4 different sizes) for $13.69.
View pizn's profile
pizn
#14 posted 09-02-2014 06:32 PM
- ChrisK
I ve used the Rockler square drive dry-lubed screws for a couple projects now, and I really like them. I got the pack that has 400 (100 each of 4 different sizes) for $13.69.
- BinghamtonEd
Thanks guys!
View Dallas's profile
Dallas
3599 posts in 2451 days
#15 posted 09-02-2014 06:33 PM
Like CharlesA, I only use deck screws. The one he shows is a SPAX screw.
Depending on the job I will also buy and use a standard Phillip’s or Robertson type deck screw.
The bottom line is that drywall screws are built to hold drywall, nothing else.
