Hand Plane Poped Threads
« back to Hand Tools forum
Forum topic by uMinded posted 09-02-2014 12:03 PM 994 views 0 times favorited 5 replies Add to Favorites Watch
View uMinded's profile
uMinded
115 posts in 1852 days
09-02-2014 12:03 PM
Topic tags/keywords: plane 5 stanley threads
I was using my #5 Stanley and the rear handle was loose, I gave it a quarter turn and it was tight for a few swipes and loosened up again. Now the threads jump and it can not hold the handle in place at all.
Is there a common solution to this? I was thinking of getting a local welder to braze it into place but that seemed a little to extreme.
5 replies so far
View Fred_Woodworker's profile
Fred_Woodworker
5 posts in 1391 days
#1 posted 09-02-2014 12:07 PM
Try the welder , im with you on this one
-- try to make the Woodworking Better , http://www.bestwoodworkbooks.com
Smitty_Cabinetshop
15353 posts in 2619 days
#2 posted 09-02-2014 12:23 PM
I’d try a hardwood shim or even JB Weld before brazing.
View Deycart's profile
Deycart
444 posts in 2258 days
#3 posted 09-02-2014 01:52 PM
Second vote for JB weld. Or you can use Loktite the version that makes a permanent bond.
View derosa's profile
derosa
1577 posts in 2836 days
#4 posted 09-02-2014 06:17 PM
loctite form a thread or a replacement insert. Usually the replacement insert involves drilling, tapping, and installing the new insert.
-- --Rev. Russ in NY-- A posse ad esse
uMinded
#5 posted 09-03-2014 11:53 AM
I had never heard of loctite form a thread but we had half a kit at work. This morning it was rock solid so we will se how it holds up. Thanks for the tip!
