Advice on Wall hung tool cabinet doors.
Forum topic by lateralus819 posted 09-01-2014 10:21 PM 898 views 0 times favorited 6 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1889 days
09-01-2014 10:21 PM
I need to build doors for my cabinet, 5 inches deep for added storage. Is there a proper way to build them? I was thinking of a mitered box with a panel. Is there a typical joint used for the corners other than meters?
View jmartel's profile
jmartel
7896 posts in 2149 days
#1 posted 09-01-2014 11:25 PM
Dovetails are the typical joint used from what I’ve seen.
lateralus819
#2 posted 09-02-2014 01:53 AM
Should have said i can’t do em by hand yet! :P
Once i get some free shop time I’m going to learn!
View theoldfart's profile
theoldfart
9701 posts in 2450 days
#3 posted 09-02-2014 02:06 AM
Kevin, give it a shot. Your work so far indicates you have the skills to pull it off. Even if it takes a few try’s, nuttin’ to loose and skills to gain.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
jmartel
#4 posted 09-02-2014 02:11 AM
No project like this one to give it a shot. It’s for the shop so it doesn’t need to be perfect.
View richardwootton's profile
richardwootton
1699 posts in 1954 days
#5 posted 09-02-2014 02:21 AM
Kevin, have you started practicing dovetails by hand yet? You’ve got a band saw, right? I know you can cut these bad boys, you’re a much more talented woodworker than myself. I have practiced random dovetails on scrap to discover that yes I can indeed cut them and make them fit, they just aren’t pretty yet.
-- Richard, Hot Springs, Ar -- Galoot In Training
View john2005's profile
john2005
1768 posts in 2177 days
#6 posted 09-02-2014 02:27 PM
I’m with the rest Lat, best thing to learn on, shop furniture.
-- In theory there is no difference between theory and practice. In practice there is.
