Hand brace (Keeping bits straight in chuck)
« back to Hand Tools forum
Forum topic by monkeyclaw posted 09-01-2014 11:32 AM 1077 views 0 times favorited 6 replies Add to Favorites Watch
View monkeyclaw's profile
monkeyclaw
4 posts in 1368 days
09-01-2014 11:32 AM
Topic tags/keywords: question hand brace auger bits trick
Hi everyone. I’m relatively new to wood working and being keen to use as many hand tools as possible i recently aquired a lovely hand brace off of ebay and having read Brits blog: The Humble Hand Brace – A Beginner’s Guide to Restoring, Buying and Using, i have started the process of restoring it to its former glory.
In the meantime I found a bunch of 12 various taper shank irwin pattern auger bits for £7.50 (bargain) from a second hand tool shop on my local market. Getting them home I decided to give them a go. I’ve never used a hand brace before and I’m amazed at how well they work, however, the bits seem to move off center whilst drilling, even when inserted straight.
I’ve read Brits blog and watched his video regarding inserting bits. Some stay straight, others don’t. What am i doing wrong? HELP!!
View Don W's profile
Don W
18715 posts in 2566 days
#1 posted 09-01-2014 12:13 PM
are you making sure the square corners of the bit sit in the groove in the chuck?
Edit: and the rule is, Pictures or it didn’t happen :-)
monkeyclaw
#2 posted 09-05-2014 02:00 PM
Thanks for the reply Don. Yeah corners in the slot, tightening until the drill bit doesn’t fall out, then turning brace upside down so drill can find it’s own level then a bit more of a tighten.
When the jaws bite onto bit they protrude from the chuck uneven, is this correct? When the chuck is fully tightened without a bit they are nice and even.
Like i say I’m a newbie, so it may just be me!
View johnstoneb's profile
johnstoneb
2915 posts in 2171 days
#3 posted 09-05-2014 02:12 PM
The Jaws should be even when tightened. What you may try is once the bit is indexed in the slots snug the jaws up slightly then pull down on the bit to make sure it is seated against the ledge on the lower end of the jaws then finish tightening.
-- Bruce, Boise, ID
monkeyclaw
#4 posted 09-05-2014 02:36 PM
Thanks Bruce I’ll give that a go!
monkeyclaw
#5 posted 09-05-2014 02:43 PM
Yep! That got it Bruce, thank you so much. Now cutting beautiful clean straight holes.
Don W
#6 posted 09-05-2014 05:18 PM
glad its figured out!!
