What should i seal coasters with?
Forum topic by BigJon posted 09-01-2014 10:58 AM 894 views 0 times favorited 4 replies Add to Favorites Watch
View BigJon's profile
52 posts in 1940 days
09-01-2014 10:58 AM
Awesome information on this site. My skills would not be nearly as developed if it weren’t for it!! So I have made a few sets of coasters. Made from cherry, oak, and other hard woods. I cant figure out what the best thing to seal them with is? Something that is easy to wipe off and dose not leave a ring… Iv tried mineral oil but condensation from a cold glass will still leave a ring. Its easy to repair though, just reapply. What should I try next? Thanks Jon
-- Im bleeding, go get my super glue and roll of black tape....
View bubbastinks's profile
20 posts in 1297 days
#1 posted 09-01-2014 11:54 AM
I’ve used wipe on poly with good results. It doesn’t build up like brush on so the water doesn’t run off onto the table, but it seems to keep the water rings from setting in.
View Grandpa's profile
3259 posts in 2606 days
#2 posted 09-01-2014 02:37 PM
epoxy based resin. Mix the 2 parts as directed then apply. There is a short pot life after mixed. Heat with a heat gun or a small torch to make it flow. It seals like glass.
#3 posted 09-01-2014 03:53 PM
I will try the poly and see how it works. Don’t have any epoxy laying around. I will go experiment with tung, Danish, and blo too latter. I was being lazy and looking for a quick answer. Thanks guys!
17763 posts in 1788 days
#4 posted 09-01-2014 03:59 PM
I would use several coats of oil based poly. I have numerous rings from glasses on my end tables with water based poly, but my dining room table that I finished with about 6 coats of oil based poly I can leave a glass sweating on there all day and there is no ring.
