What to order with a Mortise Pal
Forum topic by Laughran posted 09-01-2014 12:35 AM 965 views 0 times favorited 5 replies Add to Favorites Watch
View Laughran's profile
Laughran
72 posts in 1926 days
09-01-2014 12:35 AM
Topic tags/keywords: question router joining
For those of you that have bought the Mortise Pal, what if anything did you order with it?
Did you order your bits from Mortise Pal? What about your tennon stock, where do you buy that?
What size bits do you use the most?
In other words what did you find out you needed after you bought it?
Thanks for your time
David
-- David
5 replies so far
View AandCstyle's profile
AandCstyle
3052 posts in 2254 days
#1 posted 09-02-2014 12:53 AM
David, I have one and use it a lot instead of my POS hollow chisel mortiser. I got Whiteside bits (RU 2100, RU 4900 & RU 5200) from Amazon IIRC. I make my own tenons after cutting the mortises to ensure a tight fit. The bit diameter depends on what you intend to make-maybe 1/4” for picture frames, 3/8” for tables and 1/2” for beds. So far, I have used the 3/8” the most.
The bolts used to hold the jig onto the workpiece are brass so don’t over-tighten them which will stretch the threads. DAMHIKT. Feel free to PM me with any additional questions.
If I lost mine, I would replace it.
-- Art
Laughran
#2 posted 09-02-2014 11:08 AM
Thanks for the info Art
I think that I’ll start with a 3/8 bit and add more as needed
Is there any particular wood that you prefer to make your tenons with
Thanks again
-- David
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3361 days
#3 posted 09-02-2014 12:21 PM
I ordered the extended range mortise template set to have additional size options. I usually make my loose tenons from the same stock as the pieces to be joined. A great way to consume the scraps and cut offs. I put the loose tenons in the microwave fro about 45 second before use. It shrinks them a bit and they swell up once they come in contact with the glue.
AandCstyle
#4 posted 09-02-2014 11:24 PM
Like Vincent, I use scraps from my current project, 99% of the time it is white oak.
Vincent, that is a great tip. I will try it next time. Thank you!
-- Art
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2905 days
#5 posted 09-02-2014 11:40 PM
I started out with their 1/4” tenons
And just decided to buy the bit & bushing to come with the set.
The bit/bushing set is Whiteside (so that tells a lot) and it comes with a great centering pin. Best one I own. All 1/2 inch collet bit/bushing/pin.
Haven’t needed anything else.
Prolly going to get a little larger bit/bushing and I have been making my own tenons
You will love it.
I am using mine today to put the legs, rails and stiles on a cherry entry table.
Measure VERY closely and it is easy peasy.
I realty like doing my mortise layouts either with the stop that screws into the unit, or….... and here is an endorsement:
I like the Woodpecker Story Stick for getting PERFECT transfers on mortise marks from piece to piece.
http://www.woodpeck.com/storystick.html
Best….........Bruce
