My brand new Dewalt lathe and duplicator...
« back to Woodturning forum
Forum topic by DKV posted 08-31-2014 09:32 PM 2440 views 3 times favorited 21 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2378 days
08-31-2014 09:32 PM
Just finished painting and reassembling. In between the build and the paint I managed to play with it a bit and it seems to work well. Yesterday my Capt Eddie chisels arrived. I have also modified a couple of old chisels I have.
After a little more practice I am going to attempt a chess set for my grandson. Below are some pictures of the style.
-- This is a Troll Free zone.
21 replies so far
View distrbd's profile
distrbd
2252 posts in 2320 days
#1 posted 08-31-2014 10:47 PM
At first glance it looks like a Dewalt mini lathe ,you have made the right improvements,like the trigger,reinforced tool rest, you even bought a yellow & black safety goggles,lol.the whole thing looks well made and functional.
The chess set (last picture) looks hard to make ,it will be a good learning experience.
-- Ken from Ontario, Canada
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1423 days
#2 posted 08-31-2014 10:49 PM
Nice, it is really cool.
View DKV's profile
DKV
#3 posted 08-31-2014 11:33 PM
Capt Eddie carbide cuts pretty smooth.
View DKV's profile
DKV
#4 posted 09-01-2014 04:55 AM
My next project?
View redryder's profile
redryder
2393 posts in 2976 days
#5 posted 09-01-2014 05:42 AM
I’ve seen several of these DIY lathes over the years. Very inventive and it’s gotta save a ton of cash and looks like it can get you the desired results.
But,
I’ve always wondered if a drill can stand up to long periods of high speed use while making a turning. Or is this a good way to “fry” a drill??
What say you DKV….............................
-- mike...............
View DKV's profile
DKV
#6 posted 09-01-2014 06:02 AM
redryder, the drill is fairly new. It replaces a 1973 Craftsman that went TU not long ago. It is a high torque, 7 amp drill that turns variable to 1200 rpm. I’ve played with it a lot and like most turners I’ve watched it gets turned on and off quite a bit. After some heavy use today I put my hand on the body of the drill and sensed no excessive heat. I had the same concerns you do.
Since I do not want to hand duplicate all of the pawns in a chess set I have decided to add a router duplicator to the setup. I will be starting that tomorrow. I will be using my Bosch Colt for that job.
Also, I will not be using the lathe as frequently as a “real” turner does. The only reason I build this one was so I could turn knobs and build the chess set for my grandson. I could not justify buying a lathe just for that reason. What I will probably find out is I really like to turn wood and go ahead and buy a “real” lathe…and then again maybe not. If this one holds together, and I have no reason to think otherwise, then this one will be fine for what I want to do.
View DKV's profile
DKV
#7 posted 09-05-2014 02:57 AM
I’ve been working on my duplicator and have a question to ask of the woodturner guys out there. In the photos I have stacked all the parts and pieces I will use to build the duplicator and now I’m trying to determine the final height that the bit of the router will sit at. I understand that the height is affected by the size of the bit I’ll be using. Should I build the base that holds the router for the bit to sit approximately on the center line of the lathe or slightly above it? I will probably be using 1/4” round nose bits and be ultra cautious with the amount of wood I take off on each pass.
View waho6o9's profile
waho6o9
8070 posts in 2451 days
#8 posted 09-05-2014 04:04 AM
I vote for slightly above center about
an 1/8th of an inch.
View DKV's profile
DKV
#9 posted 09-05-2014 04:16 AM
Thanks woho6o9. I could play with shims to determine optimum and/or change in bit size.
waho6o9
#10 posted 09-05-2014 04:35 AM
You’re welcome DKV.
I think the router goes on a particular side as well.
View abcabc12345's profile
abcabc12345
4 posts in 1234 days
#11 posted 09-05-2014 04:57 AM
Dont mind me, just needing 5 posts so i can message someone.
View DKV's profile
DKV
#12 posted 09-05-2014 05:02 AM
Glad to oblige…
View DKV's profile
DKV
#13 posted 09-05-2014 11:51 PM
The first picture shows the x direction carriage and the second picture shows the keyboard slide I am going to mount to the carriage for the y direction movement. Hope to have the whole project completed soon so I can start duplicating chess pieces.
View DKV's profile
DKV
#14 posted 09-09-2014 01:07 AM
Almost done. Still have the follower arm for the template to install. I’ve played with it and it works very well. Now, on to the chess set…
View Mas's profile
Mas
57 posts in 2137 days
#15 posted 09-09-2014 01:59 AM
Looks like a pretty nice build hope you can get lots of use from it.
