Can't Get to Battery on Wixey Dig. Height Gauge
Forum topic by juniorjock posted 02-03-2009 07:26 PM 1703 views 0 times favorited 5 replies Add to Favorites Watch
View juniorjock's profile
juniorjock
1930 posts in 3887 days
02-03-2009 07:26 PM
Topic tags/keywords: wixey digital height gauge battery replacement
I need to replace the battery in a Wixey Digital Height Gauge and am having trouble getting to the battery. I can pull the tab out where the battery is but can’t get it far enough out to get to the battery. I thought I’d ask here to see if any of you can give me a little help…... before I end up breaking the tab.
- JJ
5 replies so far
View lew's profile
lew
12270 posts in 3877 days
#1 posted 02-03-2009 09:03 PM
I just pulled mine to see how it works and it looks like the plastic piece that holds the battery may be your problem. I’ll try to explain what I saw on mine-
The battery is held in place by an incomplete plastic ring. The ring goes a little more than half way around the perimeter of the battery. It stops just past the “bottom” of the battery as you are viewing the gauge when removing the batter. Maybe the plastic- because it is not a complete ring- warped some and is catching when you try to lift up the plastic battery holder. Maybe you could slip something like a feeler gauge leaf-or something similar- along the battery side to see if it would release.
If this description is too confusing, let me know and I’ll draw a picture of what I saw.
Lew
35130 posts in 4522 days
#2 posted 02-03-2009 09:14 PM
I have the Wixey digital gauge on my planer and the plastic cover comes completely off. So I’d assume that yours should also. See if there is a hang up on yours.
juniorjock
#3 posted 02-03-2009 09:14 PM
Thanks Lew, I’ll give that a try. So, the battery tray is supposed to come completely out?
- JJ
juniorjock
#4 posted 02-03-2009 09:16 PM
I think you’re right Karson. Something is catching it and keeping it from coming out. I’ll work with it some more and try not to break it.
- JJ
juniorjock
#5 posted 02-04-2009 05:49 PM
Lew, the feeler gauge worked like a charm. Thanks.
- JJ
