You might be a lumberjock
« back to Coffee Lounge forum
Forum topic by hairy posted 08-28-2014 04:21 PM 1130 views 0 times favorited 10 replies Add to Favorites Watch
View hairy's profile
hairy
2701 posts in 3525 days
08-28-2014 04:21 PM
If you ever cut your tablesaw fence and wondered where the sparks are coming from, you might be a lumberjock.
This is almost as good as when I drilled into the jaws of my lathe chuck with a forstner bit and said, “What’s that noise?”
The good news. It’s still early. I got all day to top this.
-- My reality check bounced...
10 replies so far
View DKV's profile
DKV
3940 posts in 2497 days
#1 posted 08-28-2014 04:44 PM
Now you have a crosscut sled…
-- This is a Troll Free zone.
View summerfi's profile
summerfi
3912 posts in 1680 days
#2 posted 08-28-2014 04:46 PM
Hmmm…I always thought the fence was supposed to be parallel to the blade.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View longgone's profile
longgone
5688 posts in 3301 days
#3 posted 08-28-2014 05:37 PM
Hopefully you will not do it again. I once mistakenly cut the sides of my aluminum fence on the router table because the panel raising bit was bigger than the opening I set. I learned a lesson and it will not happen again
hairy
#4 posted 08-28-2014 05:54 PM
- summerfi
The fence on my Kreg miter gauge. Strike 2
View Porchfish's profile
Porchfish
823 posts in 2525 days
#5 posted 08-28-2014 06:04 PM
Hell you meant to do than during the inventing process , right? Of course,you are part way through creating a crosscut jig/Kreg miter gauge combination ! Brilliant ! Of Course you planned it but complications have caused a rethink and rehashing of minor side effects ! I’m wit’cha !
-- The pig caught under the fence is always the one doing all the squealing !
View splatman's profile
splatman
586 posts in 1392 days
#6 posted 08-29-2014 06:51 AM
You might be a lumberjock if you turn off the TS just before completing a cut, and using the blade’s momentum to finish the cut.
When you cannot wait for the blade to stop (didn’t think of the above), so you run a scrap of wood into it to halt it.
When you keep worn out/damaged blades for cutting wood with nails.
When you want something to happen, you make it happen!
View AlaskaGuy's profile
AlaskaGuy
4118 posts in 2302 days
#7 posted 08-29-2014 04:15 PM
I didn’t know aluminum made sparks when you cut it. Mine doesn’t.
Smitty_Cabinetshop
15341 posts in 2611 days
#8 posted 08-29-2014 04:34 PM
^ Good for you!
longgone
#9 posted 08-29-2014 06:44 PM
I didn t know aluminum made sparks when you cut it. Mine doesn t.
- AlaskaGuy
Must be that new aluminum used for miter gauges with homemade Zero Clearance Inserts
woodbutcherbynight
4497 posts in 2402 days
#10 posted 09-01-2014 02:15 PM
If you have cut a board short at 66 inches instead of 6 feet 6 inches
