| Forum topic by Bob Babcock | posted 876 days ago | 557 views | 0 times favorited | 25 replies | ![]() |
876 days ago |
Topic tags/keywords: bandsaw I just installed the 6” riser block on my bandsaw and it doesn’t seem to be the correct length. I went back over everything 3 times and the 105” blades don’t fit. Completely un-tensioned, blade just won’t go on. Wheels are co-planar….amd I missing something? I’m hoping to resaw the cedar for the summer project but this is screwing me up. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
876 days ago |
I’m right with you, Bob. You have the Grizz 14” saw, correct? It uses 93” blades without the riser, and with a 6” riser it takes 105” blades. They should work fine. I think we need some pictures. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
876 days ago |
I agree with Mot that we’re gonna need some pics – or a video? If you take pics (or video) include pics of the upper wheel assembly from a couple perspectives and a shot of the tension adjuster assembly, in addition to the riser block… -- Dorje (pronounced "door-jay"), Seattle, WA |
875 days ago |
I am going to take a guess that maybe you haven’t fully released the tensioner on the top wheel? -- A mind, like a home, is furnished by its owner |
875 days ago |
Bob , I had edited the above and added that you might want to check the blade length with a piece of string too but the edit disappeared. Bob -- A mind, like a home, is furnished by its owner |
875 days ago |
Good point, Bob. Check the length of the blade. The variable might be the $20 one. -- You can discover more about a person in an hour of play than in a year of conversation. (Plato) |
875 days ago |
I had the same problem with my Grizzly 14” bandsaw after I installed my riser. There is an adjustment on the tension knob that will allow you to adjust the wheel up and down. Allowing you to fit the 105” blade. It’s hard to explain, but there is a section toward the end of the manual that talks about this adjustment. Have a look, and if you can’t figure it out I’ll try and snap some pictures on my saw and try to explain it further. |
875 days ago |
I’ll have to play some more in the daylight today. I had done pretty much everything you guys mentioned (I bought 3 new 105” blades and none fit) I’ll take a look at the tension knob adjustment. I had loosened it as much as I could see too. I’ll check it out again and let you know how it goes. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
875 days ago |
A call to Grizzley support may be in order… -- We must guard our enthusiasm as we would our life - James Krenov |
875 days ago |
I just checked my Jet 14” with riser. -- No piece is cut too short. It was meant for a smaller project. |
873 days ago |
I managed to get the blade installed by adjusting the spacer on the tension knob. Now the tension knob seems locked up. The tension still seems loose but the knob is tight. I’m really surprised by the simple mechanisms that bandsaws use. It seems like some reasonably basic engineering could make setup much easier and more precise and reliable. Maybe if I had mortgaged the house and got a Laguna. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
868 days ago |
It took some playing around with spacer on the tension mechanism, but I was able to get it to a place where I could adjust the tension and still get the blade on. Where able to get things worked out? |
868 days ago |
Hi Bob, -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
867 days ago |
“It seems like some reasonably basic engineering could make setup much easier and more precise and reliable. Hi Bob: I wondered if you got that BS working. After struggling with a similar set up for about 5 years I recently purchased a “Busy Bee 18” here for $799.00 on a special. Shown here is the for tension it spins in a circle to adjust tension and flips up to release the blade . Bob -- A mind, like a home, is furnished by its owner |
867 days ago |
test test from picassa href=”http://picasaweb.google.com/boboswin/PicsFrom2005/photo#5087535588394557010”> Picassa is calling the image a larger size than it seems to be storing to the allbum site. The top pic is stored on with service provider while the bottom on is the same image stored at Picassa. IS THIS A PLOY TO GET ME TO BUY MORE WEB STORAGE? GRRRR! Bob -- A mind, like a home, is furnished by its owner |
867 days ago |
Bob: And it was some Taiwan Engineer that designed it, and it’s being made by the lowest bidder. Hope you get it resolved. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
867 days ago |
I know how to resolve it Karson. They don’t have a feed back area so the heck with em bob -- A mind, like a home, is furnished by its owner |
867 days ago |
I managed to get the blade on and finally got everything working. Definitely a dumb design though. Bob….try photobucket.com, very easy, you can set it to resize your photos for blogging on the fly, easy copy to clipboard…lots of space…..free! -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
867 days ago |
I’ll do that .Thanks Bob -- A mind, like a home, is furnished by its owner |
866 days ago |
I checked the discussion groups and this is an ongoing problem with Picasso that they have apparently decided to ignore. To warn others: If you choose Picassa as your site to build your Web albums the software will reduce your image output sizes dramatically making you wish you had not chosen them. Apologies to Bob Babcock for hijacking this thread and also thanks for pointing me to Photobucket. Bob -- A mind, like a home, is furnished by its owner |
866 days ago |
Great Glad you got it solved. So what is your resaw capability now? -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
866 days ago |
Hi Karson: Bob -- A mind, like a home, is furnished by its owner |
866 days ago |
Bob That’s great. I’ve had good luck with the Timberwolf blades made by Suffox Machine in Long Island. They make a thin kerm resaw blade. I’ve also tried the woodslicer from Highland Hardware but I got lousey life. I did some practice cuts to check out the saw and blade, but when I went to cut the real wood the blade was dull and wouldn’t cut. I had only resawed some popular so it wasn’t tough wood. I currently use Laguna carbide tipped resaw blade. Expensive like priced per inch. but hey will also resharpen when you need it done. So you don’t have a throwaway blade. -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
866 days ago |
Hi Carson: I’m quite happy with them and they are not pricey at all. I would still like to give a decent carbide blade a shot though. Bob -- A mind, like a home, is furnished by its owner |
866 days ago |
No problem Bob…I actually enjoy seeing threads take a turn and get new life. I hope that Woodslicer from Highland was an anomaly Karson. That is the blade I just put on my saw to resaw the cedar for my Summer Challenge Project this week. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
866 days ago |
I hope so too Bob. It was a great surface finish and I got about 8 slices from a 1” board so It could cut veneer great but when I got ready to use it, nothing would make it cut ok. And Bob here is the edge from the Laguna blade. You can see the welded teeth on the blade. There is a pretty good chunk of carbide on each tooth. It gives a great edge (sanding required, but not as deep as regular blades) -- What happens in the workshop stays in the workshop. No wait that doesn't sound right. Karson Southern Delaware karson_morrison@bigfoot.com † |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
258 |
955 |
226 |
Woodworking Trade & Swap
623 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
test from photobucket
