Any hope for my cupping post caps?
Forum topic by bdresch posted 08-28-2014 02:55 AM 1079 views 0 times favorited 11 replies Add to Favorites Watch
View bdresch's profile
bdresch
141 posts in 1574 days
08-28-2014 02:55 AM
I made and installed these new post caps this weekend and after 1 rain and then sunny day they are cupping and pulling apart. The cap is 3/4” cedar, the skirting is 3/4” cedar cove. I assembled the cove to the top with SS 18ga brads with no glue. The reason I didn’t use glue was because the bottom side of the cap was already primed and painted (these were house trim boards that I didn’t end up using. Is there any way to save these? Maybe pull them apart, sand off the paint, leave them crown up in the sun to hopefully they straighten back out? Then u would use glue and prime/paint before installing. I’m hoping I don’t have to start from scratch because I’m out of cedar and there are 16 total.
11 replies so far
View Minorhero's profile
Minorhero
373 posts in 2571 days
#1 posted 08-28-2014 10:56 AM
That is a very shallow cut on the post cap itself. Usuaully when I see something that shallow and thin it is made of metal.
If you are lucky they will flatten back out as the weather changes. That being said, I think you are probably SOL. I would consider metal alternatives.
View mahdee's profile
mahdee
3873 posts in 1734 days
#2 posted 08-28-2014 12:18 PM
When you purchase cedar it is usually wet. You can pull them out, let them dry on both side and nail them back to the post.
-- earthartandfoods.com
bdresch
#3 posted 08-28-2014 01:04 PM
This cedar was in my garage for years so it’s pretty dry. I’ll try that though.
View johnstoneb's profile
johnstoneb
2869 posts in 2139 days
#4 posted 08-28-2014 01:44 PM
That cedar was flat sawn and nothing you can do will stop it from cupping.
-- Bruce, Boise, ID
View crank49's profile
crank49
4030 posts in 2937 days
#5 posted 08-28-2014 02:42 PM
I was taught to always have the end grain smiling at me when I look at the end of a stair tread or cap or shelf. That way when it cups the water will shed off instead of sitting in a bowl.
Your end grain is frowning. :^(
Also, with the grain turned over so that it wants to hump up in the middle you can put a fastener in the middle to try to hold it down and it will still allow for expansion and contraction without splitting.
When, or if, you get these straight be sure the finish is the same on both sides. That might help equalize the cupping forces.
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2336 days
#6 posted 08-28-2014 03:25 PM
I know I’m about to get chastised for this, but I’m going to suggest it anyways…
Vinyl post caps, white, at HD for $2.67 a pop. White looks like it would contrast well and match your existing door/window trim. Zero maintenance, pop them on and forget about it.
(Now ducking with my hands over my head for the negative comments I’m sure to receive)
TheWoodenOyster
1313 posts in 1901 days
#7 posted 08-28-2014 03:32 PM
Um I’ll stand with Ed on the firing line. $2.67 a pop is hard to beat.
-- The Wood Is Your Oyster
BinghamtonEd
#8 posted 08-28-2014 03:43 PM
Um I ll stand with Ed on the firing line. $2.67 a pop is hard to beat.
- TheWoodenOyster
Care to stand in front of me?
View Yonak's profile
Yonak
986 posts in 1487 days
#9 posted 08-28-2014 06:18 PM
I know I m about to get chastised for this, but I m going to suggest it anyways…
- BinghamtonEd
You shouldn’t get any backlash, Ed. Haven’t you been reading the thread about how everyone here is so nice compared to other sites .. no one is made to feel uncomfortable or challenged ?
BinghamtonEd
#10 posted 08-28-2014 06:21 PM
Oh, I always feel challenged…just not by other people.
View BurlyBob's profile
BurlyBob
5408 posts in 2231 days
#11 posted 08-28-2014 10:14 PM
I tend to agree with Johnstoneb. If you could somehow finagle quartersawn cedar you might have a better chance or work with the cupping and positioning the arc in the cup so it is on the top. A dear friend and expert carpenter showed that trick and numerous other to me years ago. It might be the only way you can use that cedar. In my small experience with cedar, it moves alot, all the time, all seasons. It’s not one of my favorite woods to work with.
Best of luck.
Burly Bob
