Without the Flocking Jokes
Forum topic by Cornductor posted 08-27-2014 04:06 AM 1678 views 0 times favorited 14 replies Add to Favorites Watch
View Cornductor's profile
Cornductor
208 posts in 2635 days
08-27-2014 04:06 AM
Topic tags/keywords: flocking box finishing
No really…... I’m in a bind here. I flocked a box with black and apparently the flocking didn’t hold well to the wet or what I thought wet paint. So can you flock over a flocked up job?
-- An investment in knowledge pays the best interest. Benjamin Franklin
14 replies so far
Cornductor
#1 posted 08-27-2014 01:30 PM
Anybody have any thoughts on this?
View johnstoneb's profile
johnstoneb
2871 posts in 2140 days
#2 posted 08-27-2014 01:32 PM
I don’t think it would look very good. Probably going to have to remove the old flock first.
-- Bruce, Boise, ID
View Minorhero's profile
Minorhero
373 posts in 2572 days
#3 posted 08-27-2014 01:33 PM
What did you use for adhesive? Folks call it paint, but if you bought the proper stuff it is not paint and it is definitely oil based. If using the proper stuff you could paint over but I am sure it would look terrible. You are going to want to remove any flock that did stick first. I don’t envy you this task.
Cornductor
#4 posted 08-27-2014 02:34 PM
I didnt know about the oil base but that makes sense. Looks like Ill need to scrape it off.
View Redoak49's profile
Redoak49
3197 posts in 1956 days
#5 posted 08-27-2014 02:38 PM
I have wanted to do flocking in a box but have been scared away from it as it looks like it is difficult and if you do not do it right will be a pain to fix.
Please post how this goes and what you did to make it work well along with a picture. Thanks
Minorhero
#6 posted 08-27-2014 03:22 PM
My flocking experience is limited (only did one box) but it came out great. I bought the adhesive and flocking material at woodcraft. Just tape off areas you do not want flocked so adhesive doesn’t go there, and then use the gun to shoot it on. The rule is when you think you have enough, put more on. Then let it sit undisturbed overnight.
There are several videos online I found helpful.
To the original poster. If you were able to clean up your brush and anything else the adhesive got on with water, then you have the wrong stuff. The adhesive is extremely messy and difficult to cleanup without something like mineral spirits etc.
View RandyinFlorida's profile
RandyinFlorida
248 posts in 2035 days
#7 posted 08-27-2014 05:04 PM
Check out craftflocking.com. They have videos. And supplies.
-- Randy in Crestview Florida, Wood Rocks!
View dgrant's profile
dgrant
47 posts in 1684 days
#8 posted 08-27-2014 05:09 PM
+1 on the flocking and adhesive from Woodcraft. I did a box two years ago and it has held up great. Pretty easy to do as well. I used blue tape to get real nice straight lines where the sides meet the top of the drawer.
View Crank50's profile
Crank50
173 posts in 1544 days
#9 posted 08-27-2014 09:06 PM
Flocking adhesive looks and smells and acts exactly like contact cement. I have used thousands of gallons of this stuff.
I used to be the engineering manager at a company that made the rubber weather sealing components for cars. You may have noticed that the window run channels are usually flocked.
Cornductor
#10 posted 08-28-2014 12:13 AM
UGHHHHH I wish I had seen bought or even known about the adhesive. Guess I’ll be trying to scrape the old flock off and reapply.
View distrbd's profile
distrbd
2252 posts in 2414 days
#11 posted 08-28-2014 01:43 AM
I have done a few boxes using LV flocking kit only thing to remember is to put a thick heavy layer of the glue/paint,then sprinkle more than enough powder on it,I mean ,when you think you have put enough,put some more,you can always collect/retrieve the flocking material that did not stick ,this is one case that too much is never too much.
Avoid touching the flocking while it’s wet,just carefully put the item (that you flocked) away for 36 hours to fully cure.
As far as I know you only get one chance to do it right,if it is flocked up,you can not re-touch it.
-- Ken from Ontario, Canada
Cornductor
#12 posted 08-28-2014 01:51 AM
So I’m beginning to see that nooo one has ever had to reflock.?
Cornductor
#13 posted 08-29-2014 01:54 AM
Ok so mission accomplished. Let me explain here how I did it.
1. Took a plain plastic scraper which I normally use to spread glue on bigger projects. Scraped off the flock into the garbage (not wanting to infect the new flockin).
2. Used my air compressor and blew out any fragments laying around the box.
3. Since I didn’t have the time to wait on the recommended adhesive I applied black craft paint again. This time is was a thick but even layer.
4. Quickly moved the box into a cardboard box and began to flock it like crazy.
5. Let it dry and shook out the excess.
With this method it worked but had wasted time in the build. Knowing now what I wish I had known before, I’m going to purchase the correct adhesive.
Thanks Jocks for all the advise and help. Here’s the finished piece.
View Jim Finn's profile
Jim Finn
2647 posts in 2889 days
#14 posted 08-30-2014 12:15 PM
I haved flocked about twenty boxes and have used oil paint and latex paint. Either worked well for me but the oil paint leaves a smell that latex does not. The trick is to get the flocking applied while the paint is still wet. Latex dries faster than oil so one has to be quick when using this. I now only use latex paint for flocking.
-- Website is https://craftingcouple.com/
