hanging air filtration sideways
Forum topic by Scott C. posted 08-26-2014 02:38 PM 1311 views 0 times favorited 5 replies Add to Favorites Watch
View Scott C.'s profile
Scott C.
158 posts in 1954 days
08-26-2014 02:38 PM
I’m looking to add a air filtration unit to my small basement shop (approx 12’x22’ with 7’ ceilings). Space is at a premium in my shop, including head room. I’ve found a used JDS-2000 unit that measures 24×34x12, overkill for my shop , but the price is good and should work well on the lowest setting.
Main question: Is there any reason this unit wouldn’t work well if hung sideways a few inches off the wall? I’m not sure I have a good place to mount in typical fashion.
-- measure twice, cut once, swear and start over.
5 replies so far
Rick Dennington
5690 posts in 3097 days
#1 posted 08-26-2014 03:41 PM
I don’t see why it wouldn’t…..As long as you’re a few inches away, it’ll work fine….I have a JDS in my shop hanging from the ceiling, and it’s sideways…..But I have 9’ walls and ceiling, too….But the space you have will work fine…..Besides, the filters are on either end, so no problem…....Here’s a couple of shots of the shop….maybe you can see it…..
-- " Don't pet the sweaty things, and don't sweat the petty things."
View bigblockyeti's profile
bigblockyeti
4981 posts in 1623 days
#2 posted 08-26-2014 03:50 PM
I can’t think of any immediate reasons why it wouldn’t work, though I would contact JDS (or any other company you’re considering) before buying something only to find it won’t do what you need it to.
Scott C.
#3 posted 08-26-2014 04:01 PM
Thanks for the input rick but I think I need to clarify. Let’s say your pictures show the unit hanging horizontally and parallel to the ceiling. I’m proposing hanging it vertically and parallel to the wall (but spaced away from the wall a few inches).
View SamuraiSaw's profile
SamuraiSaw
513 posts in 1867 days
#4 posted 08-26-2014 04:03 PM
Orientation will have zero effect on that unit’s performance. You’ll be fine and well pleased with the results.
-- Artisan Woodworks of Texas.... www.awwtx.com
Rick Dennington
#5 posted 08-26-2014 04:24 PM
Ok…I’ve got it…..You want to mount it with it hanging straight up and down…..As long as it doesn’t put a strain on the motor hanging like that (?), you should still be ok…But like bigblockyeti said, call JDS and ask first before putting it up…I’m pretty sure these units are actually made to hang horizontally, hence the hanger bolts in each corner on top of the unit…....
