Need Advice...Spraying BIN Earlex 6900
Forum topic by RocketDogs posted 08-26-2014 01:56 PM 948 views 0 times favorited 4 replies Add to Favorites Watch
View RocketDogs's profile
RocketDogs
11 posts in 1351 days
08-26-2014 01:56 PM
I have used BIN with great success brushing and aerosol cans….need to spray some cabinets in a rental unit….
my question is ….Do I need to thin….if so what do I use to thin ….Can I leave BIN in the gun for several hours so I can spray fronts and back in one outing….also what is your method of clean up….I will be spraying through an Earlex 6900 with a 1.5 tip….I have a 2.0 tip if needed….Thank you for your input
RocketDogs
View paxorion's profile
paxorion
1107 posts in 1915 days
#1 posted 08-26-2014 02:08 PM
We must be thinking the same thing…I just sprayed BIN primer straight out of the can (no thinning) yesterday, using my HF HVLP. I switched to the 1.5mm tip. It sprayed beautifully and leveled itself off. I did use the viscosity cup and found that out of the can, it was a lower viscosity than the Rockler instructions recommended. That’s why I switched to the smaller needle and gradually opened up the fluid control until I got a good stream on cardboard.
Not sure how different (better, easier, pleasant) it would be on the Earlex, but I’d imagine you’ll have no trouble like me. That HF gun bleeds like crazy…
-- paxorion
RocketDogs
#2 posted 09-01-2014 10:54 AM
Thanks for the reply….did you use a compressor driven gun or turbine…. any tips on cleaning….did you use an ammonia and water solution if so what was the mixture or did you use mineral sprits….This is what I cant find out …..I surely don’t want to ruin my gun…..glad your results were good….I like BIN and want to start using it more often….but their is a learning curve over water based…..since that’s all I have ever sprayed….thanks for your input….and would like to hear from others….any little bit of advice would help…
RocketDogs
View bubbastinks's profile
bubbastinks
20 posts in 1235 days
#3 posted 09-01-2014 11:58 AM
Bin sprays well and doesn’t need thinned. Denatured alcohol to clean up. mineral spirits won’t work. it cleans up just like any other product but with the denatured alcohol.
paxorion
#4 posted 09-01-2014 01:16 PM
Thanks for the reply….did you use a compressor driven gun or turbine…. any tips on cleaning….did you use an ammonia and water solution if so what was the mixture or did you use mineral sprits….This is what I cant find out …..I surely don t want to ruin my gun…..glad your results were good….I like BIN and want to start using it more often….but their is a learning curve over water based…..since that s all I have ever sprayed….thanks for your input….and would like to hear from others….any little bit of advice would help…
RocketDogs
- RocketDogs
It’s the HF turbine driven HVLP. For cleanup, denatured alcohol is the answer.
-- paxorion
