What bits for new Router
Forum topic by Dannnyh posted 08-26-2014 01:35 PM 1325 views 0 times favorited 18 replies Add to Favorites Watch
View Dannnyh's profile
Dannnyh
29 posts in 1626 days
08-26-2014 01:35 PM
Hi All
I’m planning on getting my first Router, the one below.
http://www.rapid-tools.co.uk/tools/45368.html#SID=380
I am looking to get a set of bits of decent quality but not stupid prices, can anyone recommend a decent brand ?
Thanks Dan
18 replies so far
View Grandpa's profile
Grandpa
3261 posts in 2917 days
#1 posted 08-26-2014 01:44 PM
CMT – buy what you need and not a kit of everything. those are seldom used bits
Dannnyh
#2 posted 08-26-2014 01:47 PM
Thanks Grandpa, CMT is a brand ?
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2611 days
#3 posted 08-26-2014 01:48 PM
I think you should buy the bits you need, as you find a need for them. Likely you will not find a quality set of bits that is going to suit all of your needs, and if you do, you’ll probably end up with a bunch you don’t need.
I think some of the common ones that I find myself using frequently are :
Flush trim bit
Pattern bit
Spiral upcut bit
Rabbeting Bit
Undersized dado bits
Roundover
Chamfer
Bowl&Tray bit occasionally
Edit : I like whiteside, Freud, CMT
Dannnyh
#4 posted 08-26-2014 01:51 PM
Thanks Ed, because I haven’t used a router before, I will need to research what bits do what jobs !
TheWoodenOyster
1317 posts in 2176 days
#5 posted 08-26-2014 01:54 PM
I agree with the other on buying bits one by one as you need them. Otherwise, you’ll end up with a bunch of bits you don’t need. I have had a lot of luck with Whiteside brand bits. They are USA made and are great quality. Looks like you might be across the pond, so I don’t know about availability to you.
-- The Wood Is Your Oyster
Dannnyh
#6 posted 08-26-2014 01:57 PM
Hi WO, yes I am in the UK, it seams that a lot of the guys on here are in the US, I will have a search and see if that brand is stocked over here.
View Fish22's profile
Fish22
83 posts in 3354 days
#7 posted 08-26-2014 01:58 PM
I will take a slightly different approach. I would buy a full set of bits from a company like MLCS woodworking. Then as you get more comfortable with your router and what bits you use most often, then you can buy those bits in higher quality. The others in the set may not be used often, but if you ever need, you have them, plus you can try different profiles on scrap to see if it works with your project.
-- Bryan, South River, NJ
View timbertailor's profile
timbertailor
1594 posts in 1665 days
#8 posted 08-26-2014 03:38 PM
I agree with Ed. Get them as you need them.
And try to stick with 1/2” shank bits for long life and better wear.
3/4” straight bit and double bearing trim bit.
1/2” ” ”
1/4” upcut and downcut spiral bit for shelf pin holes, cutting circles, and the like.
After these, buy them as you need them. I use Freud bits. Cost effective, keep an edge, and make very clean cuts.
View bigblockyeti's profile
bigblockyeti
5322 posts in 1962 days
#9 posted 08-26-2014 03:44 PM
+1 to getting what you need as you need it, a good set of quality bits can not only be very expensive up front, but may include bits you might not ever need. If you have a specific project in mind, get what you need for that project. If you’re looking for projects, woodworking magazines can offer many idea, more often than not, project details will specify what bits are used during construction.
Dannnyh
#10 posted 08-26-2014 03:56 PM
Thanks guys for all the replies, my first planned use for it was to create small recessed holes so the coach bolt heads I am using on my garden bench sit flush.
BinghamtonEd
#11 posted 08-26-2014 04:20 PM
If you’re plunging the bit in to make the holes, you’ll need something like a spiral up-cut bit. For what you’re doing though, it sounds like a forstner or spade bit and a drill would be easier/faster.
Dannnyh
#12 posted 08-26-2014 04:34 PM
Thx Ed, I was looking at forstner bits last week actually. That may well be easier as you say.
View MT_Stringer's profile
MT_Stringer
3183 posts in 3472 days
#13 posted 08-26-2014 04:48 PM
Several years ago, I bought a small set of router bits from MLCS. In fact, I bought two small sets at different time intervals. Out of those 12-14 bits, I think I have used maybe five. The rest are just sitting in the box waiting for me to dream up a project for them. :-)
But, I do use the following on a more frequent basis:
  • 3/8 and 1/2 inch roundover
  • Pattern bit
  • Flush trim bit.
  • Chamfer bit
  • Rabbet bit (comes with a separate bearing set to allow the bit to cut several different rabbets.)
    Currently, I have the rabbet bit set up in a router table to cut the recess for 1/2 inch plywood backs on the cabinets I am building (1/2 inch x 1/4 inch)
Good luck. Don’t go crazy. Buy them as you have the need and get a good one each. Skip the cheapies.
View KnickKnack's profile
KnickKnack
1094 posts in 3807 days
#14 posted 08-26-2014 06:50 PM
I’m opposed to the “buy them as you need them” school of thought at the beginning.
I started with a crappy chinese set – 1000 bits for 10 quid sort of thing – do not do that – really – that’s 10 quid for things that will do nothing.
But I really do think getting a set of decent quality bits to start out with is the way to go – I bought this set…
Trend Cutter Set
(though, if you search around, you can find exactly the same set from third parties for considerably less)
Have I used all the bits in this set?
No.
Not yet.
But almost all of them.
Many times I’ve looked in there and thought, “yeah, cool, there it is” in a situation where I wouldn’t have wanted to specifically order that bit.
Now – if you can buy quality bits over a counter within a 10 minute drive – excellent – ignore everything I just said – otherwise I think it’s great to have “something of everything” sitting in the corner ready to go.
After you’ve done some work (and, with the set, you’ll be able to do just about anything you’ll likely want to do when starting out) – then you’ll know what to stock up on.
I’m no professional, of course, but just about everything I do I do on my router.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
View Loren's profile
10477 posts in 3889 days
#15 posted 08-26-2014 07:56 PM
In the UK I’m sure available brands are different.
Trend and Elu seem like decent ones available there.
I’m interested in the 8mm shank format. Lee Valley
is a Canadian dealer that sells good quality bits in
8mm and the other formats. Good value bits.
I have CMT, Freud, and many other brands.
I would not recommend fussing about brand too much.
Real cheap bits from China can be bought and they
do work but you don’t have to buy premium brands
to get good performance from smaller diameter
cutters. Larger cutters requiring more refined
balancing or whatever they do is something companies
like Freud and CMT do well. There bits from those
makers are usually made from thicker steel so they
are heavier, while lower priced bits may be machined
from flat bar stock. Both styles work and are safe,
but the higher end bits have more mass and are often
nicely painted.
Some larger sets definitely will include cutter you’ll
never use.
The ones I find most useful are:
- straight cutters
- flush trim bits
- chamfer
- rabbet bit with different sized bearings
- set of roundover bits in different sizes
- dovetail bits only if you want to make sliding dovetails or use a dovetail jig
if you want to make mouldings or raised panels
you may do well to consider the available profiles
and buy the bits that appeal to you as you need
them,
