Bench sanding square
Forum topic by Richard Alexander posted 08-25-2014 09:55 PM 883 views 0 times favorited 5 replies Add to Favorites Watch
View Richard Alexander's profile
Richard Alexander
78 posts in 3080 days
08-25-2014 09:55 PM
Topic tags/keywords: curve shaping question router
I’ve used my Ryobi bench sander to round off the corners of a box I’m working on. I used a roundover router bit first, but I would like more of curve. My problem is keeping the box edges, so to speak, square when sanding. It tends to get uneven one way, so I switch it and focus on getting the other side even with it. Then repeat… I end up taking off more than I’d like. Are there any jigs or better methods to doing this?
-- Richard- Tulsa, Oklahoma
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2689 days
#1 posted 08-26-2014 01:30 AM
Use a larger roundover bit?
Richard Alexander
#2 posted 08-26-2014 02:23 AM
I was trying for a gentler curve than the round-over bit would allow. It’s probably a matter of taking more care when shaping, or just being satisfied with the round-over bit.
View Jim Finn's profile
Jim Finn
2656 posts in 2921 days
#3 posted 08-26-2014 02:47 AM
I make small boxes, LOTS of small boxes and I round over the corners using a stationary belt sander. I then go over this curved edge with a hand held random orbital sander to smooth out the curve. On a box with curved edges is hard to notice if they are not perfectly square.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View bigblockyeti's profile
bigblockyeti
5120 posts in 1719 days
#4 posted 08-26-2014 03:11 AM
What sized radius are you looking to create? There’s likely a bit close to the size you’re looking for.
Richard Alexander
#5 posted 08-26-2014 05:17 PM
It’s close to a 1/2 inch radius. I’ll keep playing with the router size, and following Jim’s technique to get the look I’m going for. Thanks for the suggestions.
