Hanging tool cabinet assembly and layout advice
« back to Hand Tools forum
Forum topic by lateralus819 posted 08-25-2014 08:28 PM 1149 views 0 times favorited 8 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 2130 days
08-25-2014 08:28 PM
So I have the rough shell assembled (Dry).
I used lock rabbets, and i noticed on dry assembly it’s off square but i can tilt it into square. Whats some tips to keep it square during glue up? It’s quite big at roughly 32” wide x 40” tall.
Also, how have you guys hung yours? I know a lot due french cleats. I was thinking of insetting the back 3/4” and putting the cleat in that way. That way it isn’t visible from the side and it’s not breasted out that 3/4”.
8 replies so far
View bondogaposis's profile
bondogaposis
5155 posts in 2591 days
#1 posted 08-25-2014 08:59 PM
I made these for keeping carcases square during glue up. I got the plans from Wood Magazine. The large ones are 12” and the smaller ones are 7” on a side. Made from 3/4” plywood and I put packing tape on the edges to keep them from getting glued to a project.
-- Bondo Gaposis
lateralus819
#2 posted 08-25-2014 09:04 PM
Thanks bondo! I’ll make some. I understand the smaller angles but what are the circles for?
View darinS's profile
darinS
714 posts in 3107 days
#3 posted 08-25-2014 09:19 PM
lateralus819,
I haven’t made any of these, but I’m guessing the hole is to hang out of the way when not in use.
Maybe I’m wrong, and if so, please correct me Bondo.
-- Rule 40 - If it seems like someone's out to get you, they are.
View johnstoneb's profile
johnstoneb
3072 posts in 2413 days
#4 posted 08-25-2014 09:28 PM
I run a bar or pipe clamp laterally as i am clamping and leave it ln until glue has set. I might have to make some of those.
-- Bruce, Boise, ID
View Don W's profile
Don W
19050 posts in 2808 days
#5 posted 08-25-2014 11:05 PM
I use the cross clamps as well.
lateralus819
#6 posted 08-26-2014 12:11 AM
Are you guys talking from corner to corner?
I’m kicking myself in the butt over all these rabbets and dados. Had i known what i was going to do for layout i could have done them all at the same time, and all the inner shelves would be the same length.
I have to take twice as long to check fit and length. Argh!
I ended up cutting the inner framework down 5/8” in it’s width. Which allows a 1/8” back and a 1/2” board for a cleat.
View ksSlim's profile
ksSlim
1290 posts in 3130 days
#7 posted 08-26-2014 12:41 AM
Shelf bracket form the hardware store work for clamping a box into a square configuration.
-- Sawdust and shavings are therapeutic
bondogaposis
#8 posted 08-26-2014 01:57 AM
Thanks bondo! I ll make some. I understand the smaller angles but what are the circles for?
- lateralus819
I use the hole to hold it to the carcase w/ a spring clamp while I put f clamps on the flat spots and yes I hang them by the holes too. It saves having to have 3 hands. Here is the link.
-- Bondo Gaposis
