CHERRY LOGS TO CUT UP
« back to Woodturning forum
Forum topic by Troy Cleckler posted 08-25-2014 04:18 PM 1087 views 0 times favorited 4 replies Add to Favorites Watch
View Troy Cleckler 's profile
Troy Cleckler
385 posts in 1369 days
08-25-2014 04:18 PM
I’ve got two cherry logs that I’ve been storing in my shop for several years now and wondering how to cut them for turning bowls. They’re roughly 8” or so and one end, at the base is about 10”. My 12” band saw won’t handle the log before it’s cut so do I chain saw them down the middle then band saw a circle or can I cut a little of one edge off to keep the wood thicker so the bowl could be deeper?
-- Troy. - Measure twice, cut once and fill the gaps....
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1728 days
#1 posted 08-25-2014 04:43 PM
When I’m setting up to cut blanks, I usually cut the length the same as the OD. Then I split them, or if it’s a small branch, under 7”?, I don’t split and just turn as is as I like doing Southwest hollow forms…. Jerry (in Tucson)
Troy Cleckler
#2 posted 08-25-2014 05:08 PM
When I m setting up to cut blanks, I usually cut the length the same as the OD. Then I split them, or if it s a small branch, under 7”?, I don t split and just turn as is as I like doing Southwest hollow forms…. Jerry (in Tucson)
- Nubsnstubs
I guess I’ve never seen that done. Need to research it, thanks.
View Wildwood's profile
Wildwood
2305 posts in 2133 days
#3 posted 08-25-2014 09:50 PM
I use saw buck (plenty of example on the web) to cut logs length wise with my chain saw. I will also use my band saw sled with furniture clamps to slice off sides to get flat sides.
Wish you would post a picture, might have better info.
-- Bill
View Ron Ford's profile
Ron Ford
208 posts in 1730 days
#4 posted 08-26-2014 10:07 PM
+1 with Wildwood. Make yourself a buck and use a chainsaw to slice them in half (bark down, much easier to cut than through the end grain). Orient so you are cutting through the pith since you have to take it away before the final work anyway.
If you aren’t going to turn the pieces right away, cut the length a bit longer than the diameter and seal them with Anchorseal or similar product so you have some waste to cut away any light checks or splits.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
