How to rub out Enduro Var gloss to semi gloss?
Forum topic by jimmy J posted 08-24-2014 05:01 PM 980 views 0 times favorited 1 reply Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2465 days
08-24-2014 05:01 PM
I’ve got 4 coats of Enduro on my table top, all Gloss. 2 questions:
1) how to i rub down the top coat to get to a semi gloss finish? I have some good steel wool. I’ve never rubbed anything down.
2) there are a couple of what look to be fairly good sized dust particles and also a big drip which sticks up. Is there a way to address these? hopefully via the same method at #1.
I wouldn’t mind putting one more coat on, but i’m a little shy of the amount needed for another coat.
1 reply so far
View RussellAP's profile
RussellAP
3104 posts in 2372 days
#1 posted 08-24-2014 06:39 PM
I would never use steel wool for anything. Some 320 grit should work. Just wipe it a couple times without any pressure. Then use a satin top coat. Be sure to remove the dust with a good vac and use your hand to gather the dust then use the vac on your hand. Works best.
