Milling My Own Lumber For the First Time
Forum topic by TheWoodenOyster posted 08-24-2014 11:59 AM 1450 views 0 times favorited 16 replies Add to Favorites Watch
TheWoodenOyster
1317 posts in 1934 days
08-24-2014 11:59 AM
Topic tags/keywords: milling
Hey everyone,
I’m planning on cutting down a small pecan tree this week and turning it into some lumber. I’m just sort of experimenting this round, but I’d still like it to end up usable. We plan on cutting it down with a chainsaw, and cutting to rough lengths with a chainsaw. Then, I plan to mill it using a jig on my big old bandsaw. I know that I need to:
1. mill it asap after it is cut down
2. sticker it in a way that will prevent warping and weigh or strap it down if possible
3. Paint the ends with some latex paint
Am I missing anything? An other tips I ought to know? I’ve never done this before, but I have read a lot of posts and such about it over the last few years, and I bought my bandsaw thinking that I might very well want to do some small-time milling on it at some point.
Thanks
-- The Wood Is Your Oyster
16 replies so far
View Monte Pittman's profile
Monte Pittman
29226 posts in 2337 days
#1 posted 08-24-2014 01:08 PM
Paint the ends, yes
mill it ASAP, probably not. Pecan is going to twist and warp if you slab it green even if it is properly stacked and stickered. My recommendation would be to let the log sit for a couple years first.
View Nubsnstubs's profile
Nubsnstubs
1287 posts in 1729 days
#2 posted 08-24-2014 03:30 PM
- Monte Pittman
What about the pith, or the center? That should be removed to prevent some cracking. Then you might be able to let it sit for awhile with coated ends.. .......... Jerry (in Tucson)
View MT_Stringer's profile
MT_Stringer
3168 posts in 3230 days
#3 posted 08-24-2014 03:49 PM
Hey everyone,
I m planning on cutting down a small pecan tree this week and turning it into some lumber… I’ve never done this before, but I have read a lot of posts.
Thanks
- TheWoodenOyster
Spend a night at the Holiday Inn Express and you should be good to go! :-) Just kidding.
Good luck
Mike
View Wildwood's profile
Wildwood
2305 posts in 2134 days
#4 posted 08-24-2014 04:13 PM
You did not mention where and how going to store these slabs. Definitely want to store your wood off the ground and out of the weather (no rain, sunlight, & strong winds).
-- Bill
TheWoodenOyster
#5 posted 08-24-2014 07:55 PM
I would be storing them in a garage, probably. Definitely out of the weather.
TheWoodenOyster
#6 posted 08-24-2014 08:09 PM
Also, this tree is probably only 8”-10” in diameter, would you say that is even worth the trouble? Remember, I am not trying to make a profit here, but if I can only get 3 2×4s worth of wood out of the deal, it would sort of be a bummer.
Wildwood
#7 posted 08-24-2014 09:17 PM
Now the real answer to your dilemma is take up woodturning to maximize use of the tree. All those wood chips you generate make excellent mulch everything else makes great fire wood.
-- Bill
Nubsnstubs
#8 posted 08-24-2014 09:23 PM
You can smoke with it too, but it’s kinda hard to roll.
Buy a lathe, and start making bowls.. Pecan is beautiful when formed into something that doesn’t look like a piece of wood. ................ Jerry (in Tucson)
TheWoodenOyster
#9 posted 08-24-2014 11:26 PM
Oh no. The turners are attacking! I can’t fend them off much longer!!! The draw is so strong!!! Must…Not…Buy…Lathe…!!!!
View Ub1chris's profile
Ub1chris
116 posts in 1379 days
#10 posted 08-24-2014 11:33 PM
I just picked up some logs from a neighbour who had a tree taken down. There’s 2 logs, each about 18” diameter by 5 ft long. It’s only red oak, and looks less than perfect, but the price was right. I too will be trying the whole log to lumber to woodworking thing for the first time. We’ll see how it goes…..
And I don’t own a lathe :)
Chris
View TheFridge's profile
TheFridge
9468 posts in 1485 days
#11 posted 08-25-2014 12:12 AM
Pecan is great for smokin or cooking over.
TheWoodenOyster
#12 posted 08-25-2014 12:19 AM
No worries. If I don’t end up milling the tree, it will still be put to good use in the pit.
View WDHLT15's profile
WDHLT15
1743 posts in 2475 days
#13 posted 08-25-2014 12:37 AM
Latex paint is a poor end sealer.
Ub1chris
#14 posted 08-25-2014 02:04 AM
I thought it had to be milled right away. Is it better if it dries in log firm for a while first?
TheWoodenOyster
#15 posted 08-25-2014 02:21 AM
WDHLT15: Seems like you are one of the gurus on this topic.
What is the best thing to seal the ends with? Should I just go ahead and get the anchorseal?
Also, How long is realistic to wait before milling? Turns out the log is about 12” in diameter. I know monte said a couple of years, but I may be dead from poor dust collection by then. Could I reasonably do it sooner than that?
