Biesemeyer fence face rehab
Forum topic by Bobbyjimmy posted 08-23-2014 10:16 PM 1459 views 0 times favorited 3 replies Add to Favorites Watch
View Bobbyjimmy's profile
Bobbyjimmy
3 posts in 1861 days
08-23-2014 10:16 PM
Topic tags/keywords: biesemeyer fence face
My biesemeyer fence faces need to be replaced/rehabed. Attached is a pic but the question is what kind of material is in the attached picture. I know the outside is laminate but what’s the clear stuff?
I’m also looking for ideas for the faces and any links are much appreciated.
3 replies so far
TheWoodenOyster
1313 posts in 1900 days
#1 posted 08-23-2014 10:50 PM
Not sure. Proabably some sort of really tough plastic. I have recently gotten a lot of “raw” materials such as stainless rod, clear plastic dowel rod, O1 tool steel, etc. It is a lot easier than you think to get a hold of that kind of stuff. Try a place like nationwide plastics. Google them
-- The Wood Is Your Oyster
View CaptainKlutz's profile
CaptainKlutz
246 posts in 1459 days
#2 posted 08-24-2014 10:31 AM
Looks like plain old acrylic sheet with standard contact cemented counter laminate on top to me. :)
Seems like a lot of work to make another from scratch.
If the acrylic is in good shape, laminate a new piece of formica or Wilsonart to it. Most Lowes have it, some HD also.
If the acrylic is bad, then replace it with MDF and add laminate if you want a slick surface.
If it were me and waxed MDF wasn’t working; I’d buy some UHMW-PE (ultra high molecular weight Polyethylene) sheet same thickness as the acrylic and make new fence face with it. Stuff cuts/machines easy with sharp bits, and is not too expensive.
Lots of plastic & industrial supply places carry it:
http://www.mscdirect.com/FlyerView?pagelabel=1713&search=52431921&contentPath=/sales-catalogs/big-book
http://www.plasticsintl.com/uhmw-natural-.500in-12in-24in-sheet-p-103-l-en.html
These are just places I know it exists, but may not be cheapest. Suggest you search around as prices vary by volume handled by suppliers.
Best of luck!
View Nubsnstubs's profile
Nubsnstubs
1280 posts in 1695 days
#3 posted 08-24-2014 03:42 PM
My Biesmeyer fence came with 1/2” Baltic Birch with white laminate on the faces, and edges were slot routed for black tee moulding. Simple as that with out any mysteries involved..
When you restore the faces, it might be better to just use self tapping screws and try to avoid the old holes… Also, when you do remove the old material, make sure you pound the old screw holes down to keep the fence flat…..... Jerry (in Tucson)
