Tablesaw blade don't elevate as your maximum height
Forum topic by Valete posted 08-22-2014 07:17 PM 1289 views 0 times favorited 8 replies Add to Favorites Watch
View Valete's profile
Valete
90 posts in 1481 days
08-22-2014 07:17 PM
Topic tags/keywords: question tablesaw
I recently bought a Grizzly G0715P and realized that the elevation mechanism not worked as I expect.
It up a maximum of 2-3/4” and then the handwheel gets lock. I never can up the blade to his all height of 3-1/8 like the user manual specifications.
Unfortunately this machine now is outside of USA and I can’t call or ask for a Grizzly support.
So is there any adjust that I can do it myself? I didn’t find any bolt or mechanism to remove this limitation.
8 replies so far
View hhhopks's profile
hhhopks
651 posts in 2399 days
#1 posted 08-22-2014 07:33 PM
Check the hard stop. There may be a set screw that is preventing the height travel.
Also, check for build up of debris on the screw. It may have been greased at one time and now is full of wood dust and is preventing the screw to turn at one end.
-- I'll be a woodworker when I grow up. HHHOPKS
Valete
#2 posted 08-22-2014 08:18 PM
This is a new machine, I used twice only.
The screws are clean, and didn’t find any bolt or screw that the limit the height.
View changeoffocus's profile
changeoffocus
467 posts in 1639 days
#3 posted 08-22-2014 08:22 PM
Just for the heck of it, what size blade are you using?
Valete
#4 posted 08-22-2014 08:23 PM
- Bob Current
10 in. :D
View Mark Kornell's profile
Mark Kornell
1169 posts in 2553 days
#5 posted 08-23-2014 01:04 AM
Why can’t you call Grizzly support? They will provide support for their machines regardless of where they are located.
-- Mark Kornell, Kornell Wood Design
View distrbd's profile
distrbd
2252 posts in 2468 days
#6 posted 08-23-2014 02:37 AM
- Valete
Did you verify that height (3 -1/8”) from the manual? I’m thinking 2 3/4” sounds very reasonable when you consider the arbor washer itself is ~1- 1/4”(x2),I’ll have to check my 10” R/B table saw Tomorrow to see it’s maximum height.
-- Ken from Ontario, Canada
View baldguy's profile
baldguy
18 posts in 1395 days
#7 posted 08-23-2014 03:17 AM
Just a thought, since you’ve only used it twice – did you remove all of the packing material? I know my Delta TS had a styrofoam block between the motor and table that would have limited blade height if it wasn’t removed. Maybe yours has something similar?
Valete
#8 posted 08-25-2014 12:56 PM
Thanks all for help. This weekend I found a screw under the table that has been limiting the blade height. Just a minor adjustments and now I can up the blade to all to his height.
The sad news is that screw wasn’t documented in user manual.
