Where can I find the specs for this motor?
Forum topic by JAY Made posted 08-21-2014 06:27 PM 845 views 0 times favorited 1 reply Add to Favorites Watch
View JAY Made's profile
JAY Made
202 posts in 1952 days
08-21-2014 06:27 PM
Topic tags/keywords: motor question
Hey folks today I was given a Moda Magnetics INC motor. The model # may be 60M-0236, I’m not sure. I want to use this motor for my new Beall buffing system, do you think this will work?
Please point me in the right direction.
-- We all should push ourselves to learn new skills.
1 reply so far
View bigblockyeti's profile
bigblockyeti
4993 posts in 1628 days
#1 posted 08-21-2014 06:47 PM
Is it a resilient mount motor which point towards it being of a sleeve bearing design vs. the preferred ball bearing for such an application. It is also of ODP (open drip proof) design vs. TEFC (totally enclosed fan cooled) design which works better for buffing where fine dust can be drawn into the motor. The resilient mount also indicates it is most likely from a double wheel blower, these are almost exclusively lower speed and likely 3/4hp or less. Depending on your buffing wheel size, a slow speed (1725rpm) motor could work if spinning a large diameter buffing wheel. The surface speed on a 6” wheel would be too slow with a low speed motor to be able to use effectively.
