Micro Jig SP-2-TK MJ Splitter Steelpro Thin and regular Kerf
Forum topic by bbrown posted 08-21-2014 04:41 PM 1780 views 0 times favorited 0 replies Add to Favorites Watch
View bbrown's profile
bbrown
222 posts in 3461 days
08-21-2014 04:41 PM
Never used. I’ll undercut the cheapest Amazon price on these:
$28 for the thin kerf tablesaw blade, $38 for a regular 1/8 inch kerf tablesaw blade.
$78 + $10 shipping on Amazon. I’ll take $60 and $5 shipping for both.
Thanks,
—Bill
Product info:
http://www.amazon.com/Micro-Jig-SP-2-Splitter-Steelpro/dp/B003E623C0/ref=pd_bxgy_hi_img_y
The ML SPLITTER SteelPro TK is one tough splitter. Consider a core made of stainless steel and then coated with high density polycarbonate that is the SteelPro TK. The SteelPro TK series is designed for Thin Kerf saw blades range: 0.090’’ to 0.118’’. Each package comes with 4 SteelPro Splitters, 4 Kerf Keepers, installation guide, drill guide, and drill bit for installation. dual splitter approach will utilize our mini-feather board effect to control both sides of the work piece, keeper piece and off-cut piece. Each SteelPro TK Splitter is fine-tuned to several thousands of an inch to keep pressure off the keeper piece against the fence. Once installed, you’ll be able to plug and play with the SteelPro TK because each Splitter comes with a different offset marked on each with a ”+.” And each ”+” represents 0.003’’ up to ”+++” which is 0.009’’. We have also included our plastic Kerf Keepers which are designed to prevent binding from warping reactive solid wood.
http://www.amazon.com/Micro-Jig-SP-2-TK-Splitter-Steelpro/dp/B00B03PMY0/ref=pd_tcs_subst_hi_4?ie=UTF8&refRID=1VCW0AE2C2AZQ44PQMRN
-- Bill Micah 6:8
0 replies so far
