How do I prevent shavings from slipping between the iron and chipbreaker on my hand planes?
« back to Hand Tools forum
Forum topic by Rob posted 08-21-2014 01:52 PM 2970 views 0 times favorited 7 replies Add to Favorites Watch
View Rob's profile
Rob
704 posts in 2976 days
08-21-2014 01:52 PM
I was flattening a long 2×2 last weekend with my hand planes. At first I was using my #7 and everything was going great, then suddenly on every pass a small chunk of the shaving (just a few fibers—maybe 1/32” or 1/16” wide by 1/4” long) started getting stuck about a quarter inch from one side, blocking the iron from engaging the wood on the next stroke. Even after removing the shaving, the plane also acted like the blade was dull. I switched to the #4-1/2 and it worked fine for a few strokes before the same thing started happening (I don’t remember if it was happening on the same side). I started taking it apart to sharpen the blade, but found a shaving that had jammed itself between the chipbreaker and iron. After removing the shaving, the plane worked great again, as though I had just sharpened it. I checked the #7 and found the same issue—a shaving that had jammed itself up in between the chipbreaker and iron. After removing the shaving, the #7 also sliced nice whispy shavings and even heavier shavings like I had just sharpened it.
I thought maybe there was a gap that was letting the shavings slip through between the chipbreaker and iron, but to the naked eye it looks like they’re mating nice and tight, and I’m tightening the chipbreaker screw tight, as well.
Does this happen to anyone else? Any suggestions?
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
7 replies so far
View JohnChung's profile
JohnChung
398 posts in 1979 days
#1 posted 08-21-2014 04:02 PM
Try to jam a poker card into the gap. If it can’t then the mating is good else the chipbreaker needs to be tighten down or the chipbreaker needs to be slightly bent for a greater bond to the blade. Just a slight bent.
View Rob's profile
Rob
#2 posted 08-21-2014 06:58 PM
Thanks; I’ll give that a try when I get home.
View b2rtch's profile
b2rtch
4847 posts in 2953 days
#3 posted 08-21-2014 07:13 PM
flatten the chip breaker on a stone, it should be no gap between the iron and the the chip breaker
-- Bert
View Don W's profile
Don W
18604 posts in 2472 days
#4 posted 08-21-2014 08:55 PM
http://lumberjocks.com/donwilwol/blog/23761
View upchuck's profile
upchuck
540 posts in 1570 days
#5 posted 08-21-2014 10:21 PM
Rob-
If there are shavings jamming up between the chip breaker and the flat side of a plane iron then there is a gap where there shouldn’t be one. With the chip breaker and iron tighten together hold them up to a light and see if you can see the gap from the inside out and the outside in. Does tightening or loosening the screw change the gap?
To help locate a gap you can use a cigarette paper. The thinnest feeler gauge I have is0.0015”. I think that cigarette papers are thinner. Assemble the chip breaker and blade together with a cigarette paper between the two. Does the paper pull out? It shouldn’t. Take your cigarette paper and use scissors to cut fringe on one edge of the paper. 1/4” deep cuts about 1/8” apart should do. Then assemble again like before with the fringe trapped between the blade and the chip breaker and pull on the paper. Start pulling gently and increase effort until the paper is free. All of the fringe should tear at the edge of the chip breaker If some of the fringe pieces pull through without tearing then you have located the part of the chip breaker edge that is the causing your problem. Examine this (these) area(s) closely to figure out what the problem is.
Good Luck
chuck
View MrRon's profile
MrRon
4630 posts in 3148 days
#6 posted 08-22-2014 04:24 PM
The edge of the chip breaker that contacts the iron may have a slight radius on it that is causing the wood chip to catch and get jammed.
View TobyC's profile
TobyC
580 posts in 1780 days
#7 posted 08-23-2014 12:45 AM
- b2rtch
That’s it!!!
