Can I buy a 1-1/4" diameter Shaper Spindle to fit a machine that comes with 1"?
Forum topic by Ivan posted 08-20-2014 10:49 AM 1228 views 0 times favorited 6 replies Add to Favorites Watch
View Ivan 's profile
Ivan
185 posts in 3615 days
08-20-2014 10:49 AM
I’ve been trying to find a way to pattern rout a thick profile, 4” thick. I cant find a router bit (at least in 1/2” collet) that will reach.
If I buy a Shaper that has a 1” spindle, can I buy a 1-1/4” spindle to use a larger cutter?
-Ivan
-- "Do it right the first time, you'll just kick yourself later..."
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2607 days
#1 posted 08-20-2014 12:17 PM
Not sure about the shaper, but you could use a 2” pattern bit with a collet extension to get partially through, then flip it over and use a 2” flush trim bit for the remainder.
View Gshepherd's profile
Gshepherd
1727 posts in 2439 days
#2 posted 08-20-2014 04:46 PM
I do not know about the spindle, what kid of shaper do you have? I have a PM with a 1 1/4 spndle that I have put 1 13/16 cutter heads on it with the use of hat bushings…
-- What we do in life will Echo through Eternity........
Ivan
#3 posted 08-20-2014 06:22 PM
I don’t have a shaper, so if I buy one I want to make sure I dont get too much shaper just to be able to use the 1-1/4” ID cutter.
View unbob's profile
unbob
810 posts in 2141 days
#4 posted 08-20-2014 08:19 PM
Ivan, I have only been using the shaper for about a year or so. I started with the Delta HD, then a PM 27, now a big one with a 1 1/4” spindle. In my experience so far, its best to start slowly, such as making more simple rabbits and grooves. I quickly discovered the huge forces involved in these machines doing the most basic cuts. Cutting a profile 4” width is not a good first operation to learn with. That is something I am heading toward, and why I moved to a heavy machine that is made for wide profiles. The spindle bearings in the big machines are about the same diameter as the body on a router. The smaller machines, the spindle can deflect and cause a dangerous condition-more prone to kick back. My favorite machine for sure, but needs full attention to the smallest details.
View cabmaker's profile
cabmaker
1744 posts in 3046 days
#5 posted 08-20-2014 09:27 PM
Not likely but you can bush it to 1 1/4 easy enough.
Ivan
#6 posted 08-20-2014 10:08 PM
I did find that I can use bushings to use a 1” spindle. I don’t plan on making heavy cuts and will be making sturdy sleds to hold the work while shaping.
Thanks for the feedback.
