Routing a recess for a insetting 12 inch tile in a window bench
Forum topic by cdp posted 08-19-2014 06:46 PM 2231 views 0 times favorited 8 replies Add to Favorites Watch
View cdp's profile
cdp
4 posts in 1285 days
08-19-2014 06:46 PM
I am a novice router user. My wife wants me to inset two 12 inch tiles into a wooden window bench, How can I do this?
8 replies so far
View crank49's profile
crank49
4029 posts in 2879 days
#1 posted 08-19-2014 07:19 PM
I’m no expert router user, by any stretch of the imagination, but I can tell you what I did wrong and maybe help you avoid at least one mistake I made routing a mortise bigger than the router base..
I used a plunge base router and a straight bit.
I clamped guide rails along the sides to avoid routing an oversize mortise.
The mistake I made, and you want to avoid, is routing all the material away and left nothing to support the router as I moved back and forth. Better to leave some support posts every couple of inches. You can come back and knock them out later.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2722 days
#2 posted 08-19-2014 07:37 PM
Make a template out of mdf or plywood. It is just a square that is sized the same as the tile. Make the template big enough to clamp down to the bench. Then using a plunge router and template bit, cut out the recess. The bearing on the bit will follow your template, and you can complete the cut in several passes.
Since the template is larger than the router base, you will need to use an auxillary oversized base. You can make one out of plywood. This will prevent the router from falling as it loses contact with the template.
After the recess is cut, square the corners with a chisel if needed.
It is a similar process to cutting a recess for a router table insert.
Good luck.
View cdp's profile
cdp
#3 posted 08-19-2014 09:31 PM
I think I understand that. There isn’t a lot of clearance on the wall side of the bench, so I guess I need to make my oversized base with the router close to one edge? Oh, and what is a template bit? I was thinking I could just use a straight cut bit. Thank you.
View BJODay's profile
BJODay
526 posts in 1851 days
#4 posted 08-19-2014 09:43 PM
A template bit has a bearing on it so the bearing can ride along the edge of the template. The work piece is cut but not the template.
You could also drill the bulk out with a forstner bit and use a chisel to clean out the rest. I did this for a similar project because my tiles were not perfect squares.
BJ
View cdp's profile
cdp
#5 posted 08-20-2014 12:49 PM
Interesting. I may try the forester bit as my recess will have to be very close to the wall at one point – no room for a router. I’m thinking the hardest part would be keeping the recess level, i.e. stopping the bit at the same depth repeatedly. Thanks.
View nailbanger2's profile
nailbanger2
1041 posts in 3052 days
#6 posted 08-20-2014 01:06 PM
You said you were a novice router user, how are you with a drill? I ask because most Forstner bits tell you to only use them in a drill press. It’s obvious BJOday is pretty advanced in his skill set, how about you?
-- Wish I were Norm's Nephew
View cdp's profile
cdp
#7 posted 08-20-2014 01:22 PM
Good point! At least my concern was valid – I will try this out on some scrap material first for sure. Thanks.
View fuigb's profile
fuigb
470 posts in 2866 days
#8 posted 08-20-2014 10:21 PM
I hate to sound like the nanny, but I will: clamp that damn board before diving in with the forstner bit.
-- - Crud. Go tell your mother that I need a Band-aid.
