Set up for a wooden jack plane
« back to Hand Tools forum
Forum topic by jeffb33200 posted 08-18-2014 10:23 PM 1202 views 0 times favorited 10 replies Add to Favorites Watch
View jeffb33200's profile
jeffb33200
15 posts in 1607 days
08-18-2014 10:23 PM
Topic tags/keywords: plane
Hi All,
I bought my first wooden plane recently and I can actually make shaving now after sharpening the blade. However…..the iron is really tight inside the plane body. I mean it is tight against the sides. I can’t adjust the iron laterally at all. Is this normal for a wooden plane or do I need to grind down the width of the iron? It’s so easy on a metal plane but I’d really like to use the wooden one now and again.
Thanks for any suggestions,
Jeff
10 replies so far
View lwllms's profile
lwllms
555 posts in 3281 days
#1 posted 08-18-2014 11:55 PM
Yes, Jeff. Grind the iron to width. It should taper in width by about 1/16” with the widest being at the cutting edge.
View bandit571's profile
bandit571
20012 posts in 2683 days
#2 posted 08-19-2014 12:22 AM
The iron is tight because the body has shrunk over the years.
Grinding the iron a bit would be the easier of the ways to fix it. The other is to widen the sides where the iron slides into the plane. Takes a special file called a float for that job. So, I’d say just grind the iron a bit. IF you happen to have a belt sander of some sort, use that to narrow the iron a bit. Do one edge til warm, then do the other edge. Then try for fit, keep going until yoy like the fit. Might want to address the wedge as well. Again, a trip along EACH side of the wedge to remove just a hair, and try the fit..
View upchuck's profile
upchuck
540 posts in 1665 days
#3 posted 08-19-2014 01:21 AM
Jeff-
Do what those two guys suggest. Easy fix. Grind or file the iron.
chuck
jeffb33200
#4 posted 08-19-2014 08:20 PM
Thanks to all of you. It didn’t make sense the way it is now but I was afraid to touch it in case I made things worse. Can’t wait to get home to try it but work is needed so I can get more playthings later.
View Don W's profile
Don W
18715 posts in 2567 days
#5 posted 08-19-2014 08:28 PM
I agree the iron should fit easily, but keep in mind you really don’t need much lateral adjustment for a jack. Just make the iron fits easily in and out and you should be good.
jeffb33200
#6 posted 08-20-2014 05:56 PM
Don,
I don’t know a lot about planes. If you say a jack doesn’t need much adjustment are you saying that other sizes need more adjustment? Why have it at all if the blade is ground and polished properly, the frog set correctly, etc?
Don W
#7 posted 08-20-2014 07:30 PM
Don,
I don t know a lot about planes. If you say a jack doesn t need much adjustment are you saying that other sizes need more adjustment? Why have it at all if the blade is ground and polished properly, the frog set correctly, etc?
- jeffb33200
A jack is used for course work and the blade is sharpened with a camber. Moving a camber from side to side Or laterally adjusting it) has no effect on the cutting action.
A smoother is sharpened square or close to square. When one side cuts to deep, you move the top of the cutter laterally which lines the square cutter with the sole of the plane.
A jointer would be like a smoother. If its not cutting square, laterally adjusting it will help.
So if I have a jack with out much lateral adjustment, I don’t really care.
If a blade is ground perfectly square to the sole, then you are correct, you wouldn’t need the adjustment. Keeping everything that in tune is difficult, its just easier to have adjustment.
jeffb33200
#8 posted 08-20-2014 09:26 PM
Thanks Don.
upchuck
#9 posted 08-20-2014 11:33 PM
Jeff-
Also because wood moves depending on moisture content. Many wooden planes I see have one side of the tool cracked. I think that this mostly comes from ham-handed hammer adjustments to set the blade edge square to the sole.
But I live in the desert and I also see plane irons stuck in wooden plane bodies even with the wedge removed. I think that that is from the plane body shrinking and holding the iron. I aim for a plane blade that has some side to side play with the wood body. I think that 1/16” is enough for the changes in moisture/humidity I experience here.
chuck
jeffb33200
#10 posted 08-21-2014 05:35 PM
Thanks Chuck. I’ll be trying it out this weekend.
