parts for a 71 1/2
« back to Hand Tools forum
Forum topic by zymurgist posted 08-18-2014 06:21 PM 1011 views 0 times favorited 18 replies Add to Favorites Watch
View zymurgist's profile
zymurgist
14 posts in 1374 days
08-18-2014 06:21 PM
I recently picked up a 71 1/2 off of craigslist and I am trying to locate a thumb screw for the collar. The one I have no longer seems to fit after I soaked the parts in vinegar to remove the rust. I can push the screw right through the collar. from what I can see the threading is not stripped.
18 replies so far
View Jim Finn's profile
Jim Finn
2647 posts in 2888 days
#1 posted 08-19-2014 12:39 PM
WHAT IS A “71 1/2”?
-- Website is https://craftingcouple.com/
View chrisstef's profile (online now)
chrisstef
17310 posts in 2972 days
#2 posted 08-19-2014 12:59 PM
View Yonak's profile
Yonak
986 posts in 1487 days
#3 posted 08-19-2014 01:15 PM
WHAT IS A “71 1/2”?
- Jim Finn
If you don’t know, you’re not supposed to know. If he wanted to address those of us who are not already in the know he would have named what he was referring to rather than using secret nomenclature. He only wants answers from those who have intimate knowledge of the subject, figuring those will be quality answers.
When I see reverences to acronyms and such that I’m not privy to, I normally bypass the message believing it’s not part of my interest set anyway.
View distrbd's profile
distrbd
2252 posts in 2412 days
#4 posted 08-19-2014 02:46 PM
Lol,it reminds me of this thread:
http://lumberjocks.com/topics/57108
-- Ken from Ontario, Canada
zymurgist
#5 posted 08-19-2014 03:46 PM
http://stores.ebay.com/New-Hampshire-Plane-Parts/Stanley-No-71-No-71-/_i.html?_fsub=3793982017&_sid=944709697&_trksid=p4634.c0.m322
- chrisstef
Thanks I checked there before I posted. That one does not look long enough hand it is flat on the end. The one I have is tapered kinda. I emailed him and also contacted St Jamesbay tools to see if I can locate one.
zymurgist
#6 posted 08-19-2014 03:56 PM
WHAT IS A “71 1/2”?
- Jim Finn
If you don t know, you re not supposed to know. If he wanted to address those of us who are not already in the know he would have named what he was referring to rather than using secret nomenclature. He only wants answers from those who have intimate knowledge of the subject, figuring those will be quality answers.
When I see reverences to acronyms and such that I m not privy to, I normally bypass the message believing it s not part of my interest set anyway.
- Yonak
Or if you do not know you can also “google” :0P, with knowing the part number and that it is a hand tool. I was not unclear on purpose and meant no offense. However there is at least one person in this thread that knew what I was referring to. I searched ” 71 1/2 hand tool” and the 4th entry references the Stanley 71 Hand.Plane.
I incorrectly assumed that people in the hand tools forum were familiar with the different models of hand planes.
View Don W's profile
Don W
18685 posts in 2534 days
#7 posted 08-19-2014 04:13 PM
- zymurgist
I would assume the threading is stripped either on the screw or the collar. If its not on the screw, then you either need to re-tap the collar for slightly larger thumb screw (assuming you just want a user) and pick up a thumb screw at the big box store.
zymurgist
#8 posted 08-19-2014 04:21 PM
- zymurgist
Thanks for the reply.
I am going to have to check the collar again tonight. I have the screw with me and it does not appear to be stripped. I am going to the hardware store after work to see if I can match up the correct sized screw. I just want to be able to use it for now. I only paid $25 for it so it would be nice to eventually find original parts. I found out the school where I am taking a wood working class also has a plane restoration class so I could use it as one of my class projects
- Don W
Don W
#9 posted 08-19-2014 05:11 PM
if its an original Stanley thumbscrew, you probably won’t find one. They used different threads most of the time.
zymurgist
#10 posted 08-19-2014 05:13 PM
if its an original Stanley thumbscrew, you probably won t find one. They used different threads most of the time.
- Don W
Thanks for the heads up before I go and potentially ruin the collar if it is not already stripped. Well the search goes on…
Don W
#11 posted 08-19-2014 06:32 PM
I checked the ones I have. They are 1/4×28. You should be able to find one. You may be in luck!
zymurgist
#12 posted 08-19-2014 06:34 PM
- Don W
Sweet!!!! Thanks for the advice@ I will try it out
View Woodbum's profile
Woodbum
806 posts in 3031 days
#13 posted 08-19-2014 06:43 PM
Yonak: Maybe Mr. Finn was asking because he wanted to expand his knowledge of all things woodworking. I’m relatively sure that he has no intention of joining your little secret society …now. A simple answer would have sufficed instead of a snarky answer.I am assuming that a 71 1/2 is some Stanley plane or a replica. I personally like to read a lot of different forum material in the hope that I might learn something new.Then again, you might have been kidding. We can hope.
-- "Now I'm just another old guy wearing funny clothes"
zymurgist
#14 posted 08-19-2014 06:51 PM
- Don W
Yonak: Maybe Mr. Finn was asking because he wanted to expand his knowledge of all things woodworking. I m relatively sure that he has no intention of joining your little secret society …now. A simple answer would have sufficed instead of a snarky answer.I am assuming that a 71 1/2 is some Stanley plane or a replica. I personally like to read a lot of different forum material in the hope that I might learn something new.Then again, you might have been kidding. We can hope.
- Woodbum
- Woodbum
It is a router plane like this one. http://www.hansbrunnertools.com/Stanley%20by%20numbers/Stanley%2071.htm
I have no real room in my present shop for a router table at the moment but in the interim I want to make some things that require that type of cut. I also got a Stanley 45 Combo Plane a few months ago for a real good price and I lucked out finding a set of 13 cutters locally via craigslist.
http://www.supertool.com/StanleyBG/stan6.htm
I like the idea of learning joinery the old school way first.
View comboprof's profile
comboprof
277 posts in 1700 days
#15 posted 08-19-2014 07:38 PM
Its a wonderful tool for cleaning up dados made by say repeated table saw cuts. After I got mine cleaned up and sharpened I now can’t fathom how I lived without it.
-- -- Cheers, Don K. (Michgan's Kewenaw peninsula)
