Safe Turning Glued Timber.
« back to Woodturning forum
Forum topic by Cliff posted 08-16-2014 10:29 PM 1724 views 0 times favorited 32 replies Add to Favorites Watch
View Cliff 's profile
Cliff
1274 posts in 1844 days
08-16-2014 10:29 PM
G’day,
Imagine a piece of wood 6 inches wide and any thickness from 1/4 inch to 3 inches and about 6 inches long. Glue them all on top of each other to create a block of wood 6 inches x 6 inches and up to perhaps 12 inches in length.
In theory this would give me a nice sized piece of stock for Bowl Turning. My reasoning is, I have a supply of ” Bits and Pieces” of wood in different sizes and colours and grains. I never want to waste even a scrap of wood and this seemed a good creative way to combine the woods in such a way that it is able to be Turned and is Pretty and Pleasing to the eye.
Am I on the right track? I am sure that my fellow Lumber Jocks will have some very sound advice for me.
Thank you very much. Kind Regards,
Cliff.
-- Cliff Australia : Snoring is good. It blows away all the Sawdust.
32 replies so far
View Wildwood's profile
Wildwood
2409 posts in 2255 days
#1 posted 08-16-2014 10:45 PM
I do not do much segment turning because mating surface must perfect. For segment bowls not sure want six x six square block although can certainly do that.
If want to turn lamps or other spindle projects gluing up a bunch of scrap wood makes more sense to me.
Only thing to remember is allow the glue to fully dry before turning.
http://jlrodgers.com/pdf/part-1-cut-accurate-segments.pdf
Give it a go and show us some pictures!
-- Bill
View Jim Jakosh's profile
Jim Jakosh
21117 posts in 3226 days
#2 posted 08-16-2014 10:47 PM
Hi Cliff. That will work to use up scraps. A couple thing- try to arrange them in some kind of a pattern and make sure each piece is dead flat to avoid gaps in the turned piece…..........Jim
Cliff
#3 posted 08-16-2014 11:06 PM
Hi Bill,
Thanks for your advice. Yes I can see the importance of making sure glue is fully set/dry. It could be a disaster if the piece came apart. PERHAPS TITE BOND 3 would be good?
Regards,
Cliff.
Hi Jim,
Yes the pattern Idea sounds good and dead flat surface for sure. How about if I set the table saw blade at 45.D and cut the corners off to make it a bit easier to round off with the roughing gouge?
Also it would seem that if I used a Bowl Gouge to hollow out the bowl I would be cutting across grain. Would that be ok?
Thanks Jim,
Cliff.
View TheDane's profile (online now)
TheDane
5516 posts in 3784 days
#4 posted 08-16-2014 11:28 PM
Cliff—Yes … knock the corners off whenever you can. And using a bowl gouge would be my choice regardless of the grain.
Cliff
#5 posted 08-16-2014 11:44 PM
Gerry. Thank you! I am starting to feel more confident about the grain already. Much appreciated!!!
Regards,
Cliff.
View hairy's profile
hairy
2752 posts in 3653 days
#6 posted 08-17-2014 01:59 PM
http://www.pennstateind.com/store/WXLA6W.html?prodpage=1WX
http://www.huntcountywoodturners.org/LinkClick.aspx?fileticket=HBSb8HfQJx4%3D&tabid=322
Maybe you can get some ideas from them. That is something I’ve been wanting to do.
-- My reality check bounced...
Wildwood
#7 posted 08-17-2014 06:44 PM
Any carpenter’s PVA glue works turners here including myself like Titebond II. Other than clamps, do not have the right tools to do much segment turning myself.
This Mulberry box & lid with Cherry finial glued up with polyurethane glue several years ago. Besides wanting better cap filling and did not want that polyurethane glue to harden in the bottle. Now know poly was not the best choice for segmented turnings.
Only secret to gluing up several species of wood at one time is color bleeding from darker woods into lighter color wood. A light coat of shellac prevents that.
-- Bill
View Woodknack's profile
Woodknack
12340 posts in 2501 days
#8 posted 08-17-2014 07:10 PM
I’ve read complaints about TB3 among segment turners of the glue turning dark and shrinkage. I’ve encountered that problem myself although I didn’t know the cause until reading the complaints. TB2 is recommended instead.
TheDane
#9 posted 08-17-2014 08:32 PM
I ve read complaints about TB3 among segment turners of the glue turning dark and shrinkage.
Right you are. I actually prefer the original TiteBond (red label), but if I need additional open time I will go to TBII (blue label).
Cliff
#10 posted 08-17-2014 10:10 PM
Thank you Hairy. Those are great sites.
Regards,
Cliff.
Thanks Bill. Good tip about colour bleeding.
Regards,
Cliff.
Thanks Rick M. I will take note of the glue types.
Regards,
Cliff.
Gerry, thanks again. More good advice.
Regards,
Cliff.
View Ron Ford's profile
Ron Ford
209 posts in 1853 days
#11 posted 08-18-2014 12:19 AM
I’ve had very good luck with Titebond II and have not had any problems with darkening. Remember to clamp the pieces snugly, but not so tight that the glue squeezes out and weakens the bond.
Ron
-- Once in awhile I make something really great. Most days I just make sawdust.
View Bob Collins's profile
Bob Collins
2547 posts in 3804 days
#12 posted 08-18-2014 02:38 AM
G’day Cliff, seems to be enough info there without me adding more. I’ll just wait and see the project you post.
-- Bob C, Australia. Your best teacher is your last mistake.
Cliff
#13 posted 08-18-2014 08:36 AM
Thanks Ron.It would seem that I will use Titebond II.
Regards,
Cliff
G’day Bob,
Good to hear from you Buddy. Yes it will be interesting to see where I go with this. I haven’t had a go at Bowls yet and the thought is a bit scary letting me loose on this kind of project. I ‘ll let you know if I have a successful attempt at this project. Talk to you soon Mate.
Regards,
Cliff.
Wildwood
#14 posted 08-18-2014 09:20 PM
Why do not like segment turning part 1prep for turning. Part 2 looks better, but no part 3 yet.
http://www.youtube.com/watch?v=_xdsEGxWFNQ
So much easier to throw part of a tree on a lathe and attack it!
Cliff when looked at your tool kit did not see a bowl gouge, might think about a spindle project or buy a bowl gouge.
-- Bill
Cliff
#15 posted 08-19-2014 02:53 AM
Hi Bill, Thank you for the YOUTUBE LINK Re, Segment construction and Turning. Very interesting and good ideas and tips. Bill,l I have a Bowl Gouge. Might be the way the Photo was taken of my chisels and the profile is not fully visible. But your suggestions are appreciated. Thank you.
Regards,
Cliff.
showing 1 through 15 of 32 replies
