How do you do it?
Forum topic by DKV posted 08-15-2014 08:58 PM 1651 views 0 times favorited 26 replies Add to Favorites Watch
View DKV's profile
DKV
3940 posts in 2647 days
08-15-2014 08:58 PM
When making cuts what do you rely on for accuracy? A process comparable to the picture or the measurement scale on the saw? Share your different techniques with us.
-- This is a Troll Free zone.
26 replies so far
View papadan's profile
papadan
3584 posts in 3511 days
#1 posted 08-15-2014 09:04 PM
I have a Ridgid TS2400 that I bought in 2001. I always use the built in scale to measure cuts. I used to check my cuts but found they were always right. Now I only check when changing the blade, and adjust if needed.
View Earlextech's profile
Earlextech
1162 posts in 2833 days
#2 posted 08-15-2014 09:09 PM
I’m with papadan – my Biesemeyer has been accurate for over 20 yrs
View jmartel's profile
jmartel
8154 posts in 2293 days
#3 posted 08-15-2014 09:17 PM
I’ve got a Craftsman 113.xxx with the crummy stock fence. I check it with the same steel ruler every time at the front and the back of the blade. I typically set the fence just a hair wider at the back of the blade than I do at the front. The key is to use the same measurement tool throughout the build for the project.
View TheFridge's profile
TheFridge
10275 posts in 1629 days
#4 posted 08-15-2014 09:18 PM
Tape measure, vernier calipers, and cutting a piece of scrap for the ones that have to be dead on. Tape on the fence will get me close enough on everything else.
View Gene Howe's profile
Gene Howe
10896 posts in 3571 days
#5 posted 08-15-2014 09:20 PM
My Shopsmith won’t accommodate a Biesemeyer. I do wish it weren’t so.
So, I use a combination of a pair of 123 blocks and a set of 1/8-3/4 keyway bars graduated in 1/16ths.
View Rob's profile
Rob
704 posts in 3213 days
#6 posted 08-15-2014 09:38 PM
Gauge it if you can; otherwise if you have a decent fence that’s calibrated, it should give you the same results as measuring off the blade with a ruler.
-- Ask an expert or be the expert - http://woodworking.stackexchange.com
View Bob Kassmeyer's profile
Bob Kassmeyer
227 posts in 3068 days
#7 posted 08-15-2014 09:40 PM
I use both methods, I have a hard time seeing the lines on the fence so if I want real accuracy I use a rule at the blade.
-- Bob Kassmeyer, Nebraska
View Holt's profile
Holt
276 posts in 2772 days
#8 posted 08-15-2014 09:42 PM
I try not to measure. I get one piece right then use it for reference. For first setup, I always use my green FastCap tape measure. Even if it’s not perfect, it will always be the same imperfect each layout…
-- ...Specialization is for insects.
View TheDane's profile
TheDane
5523 posts in 3806 days
#9 posted 08-15-2014 09:45 PM
I usually just use the scale on my fence. When I first got the saw (SawStop PCS), I double-checked with a ruler, but now, two years later, I trust the fence.
View NoThanks's profile
NoThanks
798 posts in 1672 days
#10 posted 08-15-2014 09:47 PM
I cut a pc 10×10 and weigh it on a scale. If it’s light I bump the fence over a little. If it’s heavy, vice a versa.
-- Because I'm gone, that's why!
View madts's profile
madts
1869 posts in 2482 days
#11 posted 08-15-2014 09:55 PM
I use a steel ruler for the most part. If I need accuracy down to the nitty-gritty, I use this system.
http://lumberjocks.com/madts/blog/40010
-- Thor and Odin are still the greatest of Gods.
View ChuckV's profile
ChuckV
3171 posts in 3670 days
#12 posted 08-15-2014 09:56 PM
I often just use the scale on my Biesemeyer fence. If it is crucial or a special situation such as a thin-kerf blade, dado blade or bevel cut, I check on some scrap. If the piece is still over-length, I might just nick the end of the actual piece as a test.
Once the fence is set for a series of cuts, I trust it for repeatability.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View pintodeluxe's profile
pintodeluxe
5757 posts in 2956 days
#13 posted 08-15-2014 10:00 PM
Tablesaw scale, unless the dado blade is installed. In that case I use a combination square.
View SteveW's profile
SteveW
394 posts in 3001 days
#14 posted 08-15-2014 11:01 PM
I took enough time awhile back, when adjusting my Biesemeyer fence scale, that I can typically rely on it for measurements on most projects.
That said, I sometimes use a Starrett ruler I bought, that is quite accurate, using it against the fence-to-blade.
-- On the eighth day God was back in His woodworking shop! SteveW
View JoeinGa's profile
JoeinGa
7739 posts in 2150 days
#15 posted 08-15-2014 11:17 PM
I just use my extreeeemly accurate “Patented Micro Hand” .... and since THIS is nine inches
well, you know the rest :-)
