Dovetail Jig Question - router bit height
Forum topic by jtm posted 08-15-2014 02:31 AM 1044 views 0 times favorited 4 replies Add to Favorites Watch
View jtm's profile
jtm
223 posts in 1510 days
08-15-2014 02:31 AM
Hi peoples,
I have a question about my dovetail router jig.
This is my first time using one of these, and I can get a close fit, but the tails are slightly too big for the pins.
I know that reducing the bit height will make the tails smaller, but I’ve run into a problem. I have the bit as low as it will go without hitting the inside of the bushing (and it may have hit it a tiny bit already). This is still too high to get the tails to fit well (I can hammer them in, but that’s too tight).
I figure there’s a reason that the bushings are made out of a soft metal like brass, but I just wanted to check with you guys first.
Is there any reason not to retract the bit a little and rout away some of the brass? I know it shouldn’t hurt the carbide, and I’m not too concerned about the accuracy of the INNER diameter of the bushing.
Just wanted to get some suggestions.
Thanks
View TheFridge's profile
TheFridge
8666 posts in 1360 days
#1 posted 08-15-2014 02:39 AM
A rat tail file would be my solution.
View ajosephg's profile
ajosephg
1880 posts in 3434 days
#2 posted 08-15-2014 08:58 PM
What brand of jig do you have?
-- Joe
View kdc68's profile
kdc68
2636 posts in 2150 days
#3 posted 08-15-2014 09:49 PM
I’ve ran into your situation where the bit needed lowered a minuscule amount for a proper fit but couldn’t because of the brass bushing. My fix was to apply wide masking tape over the router base plate. This thickens the base plate and in essence lowers the bit without the hassle.
-- Measure "at least" twice and cut once
View Sawdustonmyshoulder's profile
Sawdustonmyshoulder
456 posts in 3502 days
#4 posted 08-15-2014 09:49 PM
jtm,
Sounds to me like you have the wrong bit for the jig or the type of dovetail (ie: half-blind, through) that you are cutting. This info would be very helpful in determining the problem. I have two dovetail jigs and each one has certain bits for certain dovetails.
Here is what a bit should look like for half-blind.
I certainly wouldn’t allow the bit to cut into the bushing. It could loosen it and cause a real danger.
Here is my first attempt at using my PC 4216 dovetail jig.
Hope this helps.
-- The more skilled you are at something, the worse you are at it when someone is watching.
