08-14-2014 05:09 PM
Topic tags/keywords:
jig
Hello to all in the know! I am just starting out in fine woodworking, I can build a house, framing, drywall etc, but this is a whole different ball game. I am planning on making external doors, tables, possibly chairs as i get better. So, as a kid, a memory of watchin my old man with his bit and brace, boring out mortises for locks comes to mind. For me, looking at this Leigh Super FMT jig makes me think i could bang a door together in no time, providing the lumber is true and straight, and the jig is set up perfect.
Am i being wise to invest in this jig? Would i be better off starting out buying a drill press?
Tools i have..
Crap ryobi table saw good for nothing Router Bench planer Small circular saw, i use this for cutting a straight edge.
I have given thought to making a jig of some sort, but not into that. Having to buy the accessories for the Leigh jig puts me off making the purchase. Its a lot of money for the whole deal. Festool is money too.
I possibly want to turn this into a business in the end, so i suppose a good investment for starting out may pay off in the long run.
Up to now, my efforts on fine woodwork mostly turn out flawed for one reason or another. A few things have turned out ok, varnishing is improving, cutting straight with good sharp tools i have learned.
Do you people think i am wasting my time?
Future buys would be a band saw, jointer, a real table saw.
I have plenty of space, and want to spend money wisely on all tools.
I built a house with a hammer, c/saw, 18volt dewalt drill.
Any and all advice welcome! Thank you.
#1 posted 08-14-2014 05:39 PM
If it were me I would use the money you are willing to spend on the FMT and put toward a good cabinet saw. If one keeps ones eye out older machines pop up in the papers, Craig’s List, etc. I have never built a door but I thinks mortises could be done with a router or chopped by hand. The tenons can be done on a table saw. I have looked at the FMT but it is too costly. If, however, I cut MT a lot I might have another thought about it.
A wood worker told me a long time ago to get the following items & get the best you can: cabinet saw, band saw, router, #5 jack plane, block plane and a good set of chisels. They don’t have to be new or purchased all at once. This advice has served me well. Good luck.
-- Jerry
#2 posted 08-14-2014 05:46 PM
Well building furniture and exterior doors requires straight lumber so I would start with a jointer and good tablesaw (large contractor saw with cast iron top will do). Then add your specialty tools. For me, I use a dado blade to cut tenons, and a hollow chisel mortiser. I like the look of tradional square through tenons. If you don’t need through tenons, consider the Domino or FMT.
#3 posted 08-14-2014 06:03 PM
You need a jointer.
I’ll say hold off on the fancy router jigs. Find yourself a solid table saw with a standard miter slot configuration and get a Delta 1172 tenon jig.
Your mortises can be cut with a plunge router or by other means.
Chairmaking may involve all kinds of joinery challenges an FMT won’t help you with. It depends how ambitious you are. I make chairs and a lot of the tricky joinery comes down to hand tool skills. If you want to buy an FMT and design your chairs around the limitations of the tool, that’s fine.
The FMT is based around a shop-made version that appeared in Fine Woodworking magazine. The tool was made by the designer for doing a set of relatively straightforward Craftsman chairs with compound angled tenons on the side rails. Another, much simpler, shop made jig for cutting compound angled chair tenons is described in Jeff Miller’s book on chair making.
#4 posted 08-14-2014 06:08 PM
I have an FMT and love it! Even so, I wouldn’t suggest you buy one at this stage of your woodworking effort. I would put most of the stationary tools you listed ahead of the FMT, and quite a bit of other stuff as well. Most particularly a table saw, starting there with a good one is going to give you a leg up on the work you want to do.
#5 posted 08-14-2014 10:00 PM
Thanks folks, really appreciated!
I´d love a stint in a proper workshop to see how its done from a master. I realise the table saw is a necessity. Jointer a luxury, i dont fancy hand planes but find them satisfying to use.
I am trying to save myself time by using a jig for something which has to be pretty accurate. I seem to end up making a mess with chisels now and again due to me trying to be perfect. The idea of setting a jig up, then buzzin it with the router seems logical. Price is about the only thing against it, but if it lasts it aint so bad.
#6 posted 08-15-2014 01:07 PM
The FMT provides dead nuts M&T joints, but the wood has to be otherwise milled quite accurately (hence the need for the other tools first). About the most difficult thing is getting the router initially installed; it’s a little easier if you have a router that can be dedicated to the FMT, then you don’t have to repeat the setup every time you use it.
Forum |
Topics |
Woodworking Skill Share
Your woodworking skills are displayed for several lifetimes in each project. Have you had to compromise your project...
12027 |
Woodturning
On the lathe, by the lathe: do you have questions? frustrations? tips? This forum is for all the woodturners out there.
2105 |
Woodcarving
Relief, 3D, chip-carving, whittling; carving knives, chisels, pocket-knives, power tools. If you are a carver or want...
431 |
Scrollsawing
Intarsia, fretwork, intricate design cutting and more! This forum is for scrollsawers: share your tips, ask questions...
340 |
Joinery
Have a question? a tip/strategy to share? a challenge, perhaps? Share your "joinery" discussion here.
1370 |
Finishing
The finish, whether paint, wax, stain, or something else, can make or break a project. What are your tips and questio...
4902 |
Looking for information on designing your projects? Having difficulties reading project plans? Looking for help with ...
6691 |
Are you unsure of which tools, or hardware, you need, or which brands to buy? Investing in tools and hardware can be ...
28047 |
CNC Woodworking
Questions and answers about CNC machines, tooling, best practices, and projects.
211 |
Hand Tools
Wood, your hand tools, you and a little know-how. Share your questions, tips and strategies for the use and maintenan...
5404 |
Jigs & Fixtures
Using a jig is like having a couple extra hands helping out. Show us your jigs, share your tips, strategies and, of c...
1417 |
Wood & Lumber
Different wood requires different woodworking strategies - from cutting to finishing. Share your tips and challenges ...
6232 |
Before you pick up those woodworking tools, take the time to ensure your safety in the shop! Eyes, ears, fingers, and...
1387 |
Focus on the Workspace
Are you looking for or do you have tips to share regarding the workshop? Storage, equipment placement, efficiency, an...
2153 |
If you are selling your work, then you have entered a woodworking dimension with added complexity and stress. If you...
1186 |
Woodworking Trade & Swap
All of us are holding onto treasure in our shops, that we either don't need, don't want, or could part with if presen...
4754 |
LumberJocks.com Site Feedback
Connect with the Website Gurus and tell us what you are thinking, suggestions, problems, functionality issues, and so...
2200 |
Coffee Lounge
Need a break from all the standing and wood dust? Chat with your Forum Friends about their projects, their life, thei...
8844 |
