Forum topic by footprints | posted 08-13-2014 04:05 PM | 2070 views | 0 times favorited | 7 replies | ![]() |
Does anyone have a bandsaw jig that cuts arc shaped segments that are edge glued to form a round table top? The segments start at zero at the center and expands (becomes wider) as you move radially outward. -- Ray, Lakeland, FL |
7 replies so far
#1 posted 08-13-2014 04:11 PM |
A lot depends on how large the segments are and how accurate you need to be. I have problems in cutting arcs on the band saw that are really accurate and the cuts smooth. I have made some jigs to move the wood I am cutting in a circle but never been 100% satisfied. Basically, it is just a plywood section that has a center post and then arms to swing the piece. I end up using a router jig to cut round segments. I have cut small ones and up to about 36” radius arcs with the router. It gives me a clean edge and accurate arc. I will usually use a spiral router bit to do the cutting. |
#2 posted 08-14-2014 03:55 AM |
Ray, when you say starts at the center and gets wider as you go outward, do you mean you want to cut pie-shaped pieces ? ..Or do you mean a spiral cut of some fashion ? If you don’t get a good answer can you post a sketch of what you mean ? |
#3 posted 08-14-2014 05:46 AM |
You can cut them out with a template… making the |
#4 posted 08-14-2014 06:02 AM |
Ray, You may want to ask degoose he is an expert on arcs. -- Regards Robert |
#5 posted 08-14-2014 01:56 PM |
I make up my own as needed for elipticals which I think is what your after. Pretty simple mine only get a little slow when setting up for long major radius s for conferance table and the like I cut my templates with a shop made router sled then use the templates to panel pilot the substrate and subsequently am able to panel pilot the finish top from there as well as any edgebandings Incidentally the router sled attaches to the articulating arms of the eliptical jig set up which has been successfully and accurate for me up to major radius s of 20 ft. Or so This may not be helping you any but I I have cut lots of ellipses via the bandsaw, jigsaw but only where extreme accuracy directly from the machine is not critical. Enjoy the journey. ( study up a little on major and minor axis. Key ingredients) |
#6 posted 08-14-2014 08:33 PM |
Yonak, I am trying to cut spiral segments. -- Ray, Lakeland, FL |
#7 posted 08-14-2014 08:46 PM |
I would rough cut at the bandsaw, and save the finish cutting for a router and template. Good luck with it. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6696 |
28067 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8846 |
