Reviews for a Grizzly G0449 37" Drum Sander?
Forum topic by CW3 posted 08-13-2014 02:05 PM 2605 views 0 times favorited 2 replies Add to Favorites Watch
View CW3's profile
CW3
1 post in 1352 days
08-13-2014 02:05 PM
I am looking at buying a used Grizzly G0449 37” drum sander 2011 model year and am unable find any reviews on it. Does anyone have information they can share on it. Also what would be a fair price, they are asking $1300
Thanks
Chuck
2 replies so far
View Gshepherd's profile
Gshepherd
1727 posts in 2171 days
#1 posted 08-13-2014 06:23 PM
Chuck, Look at a SuperMax sander, I picked up one 4 years ago. Dual Drum 37” for 2100.00 A single would be somewhat cheaper. Good Solid machine.
-- What we do in life will Echo through Eternity........
View Mark Kornell's profile
Mark Kornell
1169 posts in 2500 days
#2 posted 08-15-2014 04:02 AM
Chuck,
I have a G0449. I like it.
It is pretty easy to set up and align. The manual is online if the machine doesn’t come in with it, walks you through the process step-by-step with pics. I have my drums aligned to within 0.001” side to side. The regular maintenance procedures are similarly documented and straightforward.
The dust collection works pretty well when hooked up to a.suitable DC. I have a ClearVue CV-MAX, and I don’t consider that overkill for the application. In fact, something in that class would probably be the minimum you’d want to use.
It does suffer from all the defects drum sanders normally have. Sandpaper changes are straightforward but take a few minutes. The long drums flex minisculely when rotating leading to waves in the sanding. More noticeable in the middle of the sanding area, not as much near the sides. The amount you can take off in one pass is fairly small, even with coarse sandpaper.
I don’t consider the machine to be suitable as a finish sander. You would need to do some hand sanding or other type of surface prep as a.final.step prior to finishing. Surfaces don’t need a lot more prep, just that they do need some.
A.widebelt is a better machine for a number of reasons, but they are also a lot more money. $1200 for that machine seems like a good deal – about 1/3 new cost – if it is in good working condition.
You will need.a.240V/60A circuit for the machine, so make sure you have the electrical capacity.
-- Mark Kornell, Kornell Wood Design
