Tuning up chisels - a quick [probably stupid] question
« back to Hand Tools forum
Forum topic by HibbittyDibbitty posted 08-13-2014 12:45 AM 2593 views 0 times favorited 23 replies Add to Favorites Watch
View HibbittyDibbitty's profile
HibbittyDibbitty
8 posts in 1618 days
08-13-2014 12:45 AM
Topic tags/keywords: question sharpening chisels
I fully understand how dumb some of you will think I am for asking this question. Trust me, you and I are in agreement. So no need to post a reply telling me as much. Anyway, here goes:
I keep cutting my fingers while sharpening and/or using my chisels. Not on the cutting edge, but on the long edge where the blade’s back meets its side at 90 degrees. When I was using cheap-o, big box chisels, I just ran a fine stone over those edges a couple of times to put a little micro-round on the edge, but I’ve just bought some less-cheap-o Narex and Stanley 750s and I’m hesitant to do the same thing before making sure I’m not screwing up big-time. To my mind, I want the sides to be square to the back, but I can’t imagine that it’s necessary to have a perfect 90 degree edge all the way from the bevel to the shoulder, right? Am I completely off the deep end here, or is this a common problem?
23 replies so far
View dirtycurty's profile
dirtycurty
44 posts in 1605 days
#1 posted 08-13-2014 12:52 AM
I can’t help you with your question about chisels, but what I wanted to tell you is that the only “stupid” question is the one you don’t ask.
View Airframer's profile
Airframer
3043 posts in 1979 days
#2 posted 08-13-2014 12:53 AM
I have the exact same problem when I sharpen and use my Chisels. I had never thought of putting a slight round on the edge. I’ll wait and see what others say on the issue but for now I just wrap a bandaid around the offending finger and let the chisel rest on it instead of skin.
-- Eric - "I'm getting proficient with these hand jobbers. - BigRedKnothead"
HibbittyDibbitty
#3 posted 08-13-2014 12:54 AM
Agreed, of course. But they can still expose the stupidity that led to them. I’m holding out hope that I’ll be vindicated though.
HibbittyDibbitty
#4 posted 08-13-2014 12:56 AM
I have the exact same problem when I sharpen and use my Chisels. I had never thought of putting a slight round on the edge. I ll wait and see what others say on the issue but for now I just wrap a bandaid around the offending finger and let the chisel rest on it instead of skin.
- Airframer
Eric, the fact that I’m not the only one with this problem is just as valuable to me as a quick solution.
View Pezking7p's profile
Pezking7p
3217 posts in 1678 days
#5 posted 08-13-2014 01:01 AM
I just try not to cut myself, which usually means being careful when paring. The only reason I can see for keeping it sharp all the way up the back is when you sharpen your chisel to that spot on the chisel it won’t be sharp all the way out to the corners. But what can a couple thousandths of unsharpened corners hurt?
I say knock them down with a few swipes, but I’ll wait for someone more knowledgeable to chime in as well.
-- -Dan
Airframer
#6 posted 08-13-2014 01:02 AM
Yep usually a few minutes into chisel use I will see some DNA left on the project. After making sure I was still 10 and 10 I’ll notice some slices on the side of my guide hands pointer finger where the chisel rests and slides when paring. Figured I was the only one as well and just chalked it up to me being a dumba#^.
View TheFridge's profile
TheFridge
9608 posts in 1512 days
#7 posted 08-13-2014 01:04 AM
I’d leave the last inch or so near the cutting edge alone and round over the rest.
View DaleM's profile
DaleM
958 posts in 3410 days
#8 posted 08-13-2014 01:21 AM
I can only think of one reason for leaving them sharp on the edge. That sharp edge works well when trimming edge banding on plywood. If you haven’t done this before, the iron on banding is slightly wider than 3/4 inch ply and sliding the chisel edge along to trim it flush is the best way I have found so far. Of course, you would only need to keep one chisel sharp for that, so I don’t see any problem with rounding the rest of them slightly.
-- Dale Manning, Carthage, NY
View bigblockyeti's profile
bigblockyeti
5140 posts in 1747 days
#9 posted 08-13-2014 02:10 AM
I knocked the corners of mine off too. I don’t need any part of the chisel that sharp, except for the cutting edge.
View JohnChung's profile
JohnChung
410 posts in 2101 days
#10 posted 08-13-2014 08:23 AM
I haven’t gotten to that situation yet. The edges should be crisp but not sharp like a blade. If it is that sharp just use a leather strop. It will knockdown the sharp edge.
View JayT's profile (online now)
JayT
5678 posts in 2237 days
#11 posted 08-13-2014 11:20 AM
I don’t see any issue with knocking down those corners, leaving the last little bit near the cutting edge alone. That crisp, sharp corner is probably the result of flattening the chisel back. At least it shows you did a good job of flattening. :-)
A couple strokes on a strop or your finest stone sould take the sharp edge off without affecting chisel shape. If for some reason you use up that much chisel in your lifetime, the back would need done again.
JayT
#12 posted 08-13-2014 11:21 AM
Double post
JayT
#13 posted 08-13-2014 11:23 AM
Triple post—the interwebz has gone nuts.
View Tim's profile
Tim
3812 posts in 1988 days
#14 posted 08-13-2014 06:14 PM
Here’s what highland hardware has to say about it in the sales blurb on their Narex premium chisels:
“like most chisels, they’ll feel better and work better after you’ve gentled their long edges and flattened their backs.”
I assume that means the sharp side edges that I too have been a victim of being cut by. I guess I can’t see how they’ll work better but it’s better than being sliced up. I also just assumed I was the dumb@ss that didn’t know better, but many of us are learning on our own from the internet instead of from a mentor or shop like back in the day so it’s better to ask than not know.
TheWoodenOyster
1317 posts in 1961 days
#15 posted 08-13-2014 09:12 PM
You can round those edges off. I still need to do that with my chisels, actually. You aren’t crazy.
-- The Wood Is Your Oyster
