Warped Cutting Board, help!
Forum topic by Steve Kreins posted 08-12-2014 08:59 AM 1025 views 0 times favorited 2 replies Add to Favorites Watch
View Steve Kreins's profile
Steve Kreins
358 posts in 1656 days
08-12-2014 08:59 AM
Topic tags/keywords: question
As some of you know I have cancer and the past two weeks have been less than fun and games.
I had a cutting board, long grain, glued up and ready to sand when I got sick. I do most of my cutting and sanding in my covered patio. I know better than to leave a piece outside, but I had no choice this time because I got very sick, veru suddenly. It sat under the patio cover, but exposed to high humitity and heat for about 10 days.
It now has a nice bow in it of about a 1/4 to 3/8 of an inch, side to side. I put inside and some of the warp came out as it dried, but not all.
Any ideas on how to “Unwarp it Scotty”? Or Beam Me up Scotty to my happy place.
-- I thank God for everything, especially all of you!
2 replies so far
View mahdee's profile
mahdee
3888 posts in 1792 days
#1 posted 08-12-2014 12:05 PM
You can use 4 boards, place 2 of them on each end of the cup, get the other two boards and place them over the end of the previous ones and clamp. Tighten the clamps a little bit at a time with the bow side exposed to the elements.
-- earthartandfoods.com
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2394 days
#2 posted 08-12-2014 12:05 PM
If you’re sure that the moisture content has reached equilibrium, if you have a planer, you could just pass it through that. If it’s rocking, a couple dabs of hot glue on a piece of plywood should hold it. Otherwise, hand plane it, or find someone with a planer. It’s going to be thinner than you’d planned on, but it is what it is.
Edit : I warped a board by leaving it sitting on bare concrete for a week. You could try that.
