Routed Dadoes
Forum topic by mIps posted 08-11-2014 07:49 PM 1208 views 0 times favorited 11 replies Add to Favorites Watch
View mIps's profile
mIps
188 posts in 2049 days
08-11-2014 07:49 PM
Topic tags/keywords: question router
I need to make some dadoes in plywood for a shop project. The piece of wood is too large to safely handle on my own on the the table saw so I thought I’d try using a router. The trouble is I need a 3/4” wide dadoe and only have a 1/2 router bit.
My thought was to set one straightedge where I want one side of the dadoe to be and the other straightedge 1/4” from the other side of the router base so that I could follow the first one, then move over and follow the other back.
Is this a reasonable technique or should I try something different?
-- Be honest, honorable, kind, work hard, and generally be awesome.
11 replies so far
View bondogaposis's profile
bondogaposis
4722 posts in 2346 days
#1 posted 08-11-2014 07:55 PM
Yep, that is the way i do it. Get one guide rail set up and clamped then use the shelf stock for a spacer to set the other guide rail and the dado width will be just right.
-- Bondo Gaposis
View ajosephg's profile
ajosephg
1880 posts in 3556 days
#2 posted 08-11-2014 07:55 PM
That will work. Just remember that 3/4” plywood isn’t 3/4”.
-- Joe
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#3 posted 08-11-2014 08:00 PM
You could try this type of exact width dado jig, inspired from Woodsmith Shop plus a few modifications.
http://lumberjocks.com/pintodeluxe/blog/34885
Otherwise you can clamp two straightedges parallel, however I would recommend using a spacer. Do test cuts with the router and different spacers until the dado width is correct. Test it on scrap and see if it is repeatable.
Third option is to buy an undersized plywood 3/4” plywood bit, or full 3/4” bit and cut the dado in a single pass.
Fourth option, make a 1/2” dado. Then rabbet the mating piece to a 1/2” tongue.
View timbertailor's profile
timbertailor
1594 posts in 1419 days
#4 posted 08-11-2014 09:38 PM
That is what I would do. Everyone should have two low profile contractor’s clamps! Versatile and save you the trouble of making a jig.
TheWoodenOyster
1313 posts in 1930 days
#5 posted 08-11-2014 11:14 PM
Bondo has it right.
That will work. Just remember that 3/4” plywood isn t 3/4”.
- ajosephg
^ Don’t ignore this
-- The Wood Is Your Oyster
View MT_Stringer's profile
MT_Stringer
3168 posts in 3226 days
#6 posted 08-11-2014 11:49 PM
Check out The Wood Whisperer on You Tube. He has an exact width dado jig. Iy works as advertised.
View txn's profile
txn
139 posts in 1454 days
#7 posted 08-12-2014 01:03 AM
Rockler has a plywood router bit set that has the actual size of all the plywoods
View HerbC's profile
HerbC
1754 posts in 2854 days
#8 posted 08-12-2014 01:42 AM
- txn
Unfortunately there’s no real “standard” actual size for any of the plywood thicknesses you’ll get in most stores.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Paul's profile
Paul
721 posts in 1560 days
#9 posted 08-12-2014 03:01 AM
- txn
This is false. Take a caliper to any piece of plywood and you will find deviations of thickness. If you buy from the big box store it’s a much larger deviation than if you buy from a reputable lumber yard.
Paul
View John's profile
John
244 posts in 1576 days
#10 posted 08-12-2014 03:07 AM
+1 for the wood whisperer exact width dado jig. Works great. Its all I use because I don’t have a dado blade for the table saw.
http://www.thewoodwhisperer.com/videos/exact-width-dado-jig/
Take the time to build the jig, you’ll be surprised how often you use it. IMO
-- I measured once, cut twice, and its still too short...
View mIps's profile
mIps
#11 posted 08-14-2014 02:19 AM
I tried building one of those exact fit things and it didn’t work worth a darn. Probably the fault of the builder, but still.
