Goo Gone discovery for paint removal from finished surface
Forum topic by TopamaxSurvivor posted 08-11-2014 12:31 AM 1292 views 0 times favorited 9 replies Add to Favorites Watch
TopamaxSurvivor
18269 posts in 3673 days
08-11-2014 12:31 AM
Topic tags/keywords: goo gone paint removal finished surface
I had some spray paint on a stained and finished door do to less than perfect masking. The door was stained and finished before we bought the house. It is not a water based finish. The paint had cured for several days.
Without any good options to clean up the mess, I tried Goo Gone. Much to my amazement, it took the paint off very well. The only noticeable effect is a bit of polishing of the finish in the area that required quite a bit of scrubbing. Nothing noticeable in the minor over spray areas.
9 replies so far
View CoolDavion's profile
CoolDavion
434 posts in 3821 days
#1 posted 08-11-2014 01:47 AM
I’ve used a Mr. Clean Magic eraser on our casings.
Just go slow and check progress often as you clean.
-- Do or do not, there is no try!
View poopiekat's profile
poopiekat
4355 posts in 3731 days
#2 posted 08-11-2014 02:02 AM
There’s also a product called “Goof-Off” sold in paint stores and hardware stores. Sometimes also a ‘graffiti remover’ can be used, but it was never explained to me how it will safely remove paint from a painted surface.
I understand the magic ingredient in some of these is Butyl Cellusolve which is sold in major paint stores. It has the characteristics of getting in between two surfaces like a penetrating oil would. Pro painters use it to clean up paint spills from carpet, etc. I first heard of this stuff in high school, where it was used to un-seize stuck engines.
Goo Gone is an excellent idea!
TopamaxSurvivor
#3 posted 08-11-2014 02:08 AM
I was so surprised it worked without making a mess of the door surface, I thought I’d pass it along.
View stefang's profile
stefang
15881 posts in 3331 days
#4 posted 08-11-2014 10:19 AM
Just send me a barrel of it to Norway Bob.
View Lenny's profile
Lenny
1593 posts in 3524 days
#5 posted 08-11-2014 11:40 AM
Thanks for sharing this info Bob.
-- On the eighth day God was back in His woodworking shop! Lenny, East Providence, RI
View bluekingfisher's profile
bluekingfisher
1250 posts in 2976 days
#6 posted 08-11-2014 12:15 PM
Glad to hear you had a satisfying result on what could have otherwise been a beech of a job.
-- No one plans to fail, they just, just fail to plan
TopamaxSurvivor
#7 posted 08-11-2014 08:09 PM
You aren’t that bad a painter are you Mike? :-)
UR welcome Lenny. Hope you don’t need it, but it is good to know if you do ;-)
David, I thought I was in deep dodo when I pulled the masking tape. Not sure why I decided to try Goo Gone before sanding and trying to match the finish. Glad I did ;-)
View nailbanger2's profile
nailbanger2
1041 posts in 3140 days
#8 posted 08-11-2014 08:26 PM
I don’t know about Goo Gone, but Goof Off has quite a bit of Xylene or Xylol in it. It is a very powerful solvent that was used to dilute epoxy back when we went through gallons at a time. As a matter of fact, I just have a can of that in the truck for any problem overspray. Like said above, go slow and check your progress.
-- Wish I were Norm's Nephew
TopamaxSurvivor
#9 posted 08-12-2014 03:42 AM
I have no idea what is in it, just happy with the test and results ;-)
